Home > In Car Electronics > Rear fog lamp not working
JellyBean
So, I replaced the head unit in my Defender and all is working well with exception of the rear fog lamp. Neither the small light on the switch or the lamp itself comes on. Everything else is as it was in working order. What might I have done?
Post #446825 17th Aug 2015 2:36pm
mk1collector
Unplugged the switch maybe? Ray
My build thread
Post #446835 17th Aug 2015 2:49pm
JellyBean
Ray - I thought that myself, but when I checked the switch it was plugged in and so far as I can see is as it should be.
Post #446859 17th Aug 2015 3:53pm
K9F
Got a multimeter?
Check fuse 26 rated at 10 amps. There is also a rear fog lamp ecu. Ultimately a voltage check at the fuse output and at the light will tell what's going on or not as the case may be.
The system is earth switched on the switch pin4 or header point K109 terminal 14 if either of these are detached this too would cause your symptoms. It may 'look and feel' plugged in but is the circuit compromised? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #446860 17th Aug 2015 3:56pm
Worth checking the connector on the rear of the switch is firmly pushed home too.
I assume you already have done this though..
Post #446868 17th Aug 2015 4:32pm
scotiach
Switzerland 2015 Defender 110 Puma 2.2 SW Scotia Grey
Don't want to suggest something so simple but the light and switch only illuminate when the lights are on. I also thought I had done something wrong here when I installed the HU, but then realised my light on/off confusion.
Post #447002 18th Aug 2015 8:05am
JellyBean
Scotiach - thank you! That's was EXACTLY my error too - all is now well.
And thank you everyone else - fortunately not too complex a problem, although I feel like a lemon ...
Post #447144 18th Aug 2015 4:50pm
mk1collector
Rolling with laughter at least it's sorted Thumbs Up Ray
My build thread
Post #447162 18th Aug 2015 5:44pm
Kretchman
New Zealand 2008 Defender 90 Puma 2.4 SW Indus Silver
Life saver. You just saved me 50 quid.
Post #929007 8th Nov 2021 5:05am
