Home > For Sale & Wanted > [Wanted] 110 Side Steps - XS
Page 1 of 3 123>
tasr12
England 2002 Defender 110 Td5 CSW Zambezi Silver
We should be collecting our '02 TD5 110 later this week. The first thing I'd like to do is take off the individual steps and put on some running steps. If anyone has any they've removed and want to free up some space please drop me a line. Ideally I'm after the XS style.
Looking forward to getting back in a Defender after a 9 month stint without one.
Close to Salisbury for collection would be ideal....
Cheers.
T.
Post #446665 17th Aug 2015 5:52am
airpusher
Wales 2006 Defender 110 Td5 XS DCPU Zambezi Silver
Hey Tasr12,
I have a set I took off mine.
The main body is fine but the outriggers have surface rust. Sadly I'm no where near Salisbury, I'm in South Wales though. I'm looking for about £90 for them. I've no idea about postage as they are big!!
HTH 2006 Defender Double Cab- Zambezi Silver
Post #446701 17th Aug 2015 8:07am
tasr12
HTH,
That's pretty much what I'm looking for. I may be able to get Bristol way this weekend/early next week if you happen to be coming across the bridge?
Cheers.
Post #446725 17th Aug 2015 10:11am
airpusher
Hey,
Sadly I'm not around over the weekend as it's my little ones birthday this week. If your not in a rush then I'm sure we could come to some arrangement. 2006 Defender Double Cab- Zambezi Silver
Post #446762 17th Aug 2015 12:28pm
tasr12
That may wprk thanks. No particular rush other than wanting to get stuck in while I have the time! Have you still got the boots for steps?
Cheers. 2002 110 CSW TD5, Zambezi Silver
1995 110 CSW 300TDi - SOLD
Post #446767 17th Aug 2015 12:44pm
airpusher
Boots? Bolts? If so yes, there is a bag attached with the bolts I'll have a check too and add any that look to be missing etc.
They go into rivnuts on the side of the chassis frame. I had to put them in on mine as they weren't present. 2006 Defender Double Cab- Zambezi Silver
Post #446783 17th Aug 2015 1:23pm
tasr12
Apologies, meant bolts!
On my 300TDI they just bolted on using nuts and bolts, do you mean yours needed captive bolts on the chassis points?
Post #446790 17th Aug 2015 1:40pm
airpusher
To be honest they have sat in the garage for ages now so I can't remember.
They fitted very similar to this
http://www.sidesteps.co.uk/fitting/defender_110_steps.pdf
except the stays need to be bolted to the chassis rather than clamped as per those instructions. The holes were present but not the rivnuts. In the clamped photo just off to one side you can see the rivnut 2006 Defender Double Cab- Zambezi Silver
Post #446794 17th Aug 2015 1:48pm
tasr12
Thanks for that - I'll be needing rivnuts then! 2002 110 CSW TD5, Zambezi Silver
Post #446797 17th Aug 2015 1:51pm
airpusher
Quite possibly!
I've read quite a few people didn't bother with the stays and when I first fitted them, till I got rivnut I didn't.
They just counteract the swing when people stand on them. I may have some left from doing mine, I'll have look later. You may be luck and there may be some already present. 2006 Defender Double Cab- Zambezi Silver
Post #446800 17th Aug 2015 1:55pm
tasr12
I pick up the TD5 on Thursday so will have a look then.
Post #446812 17th Aug 2015 2:20pm
Stiff1
Hi, if airpushers don't come off for you I have a set recently removed. All bolts present including a new set of rivnuts located in Truro, Cornwall.
One has a bit of a dent on the underside and a couple of spots where the powder coating has peeled otherwise are fine.
Will eventually get round to listing them for about that money.
Post #446969 18th Aug 2015 12:45am
tasr12
Many thanks. 2002 110 CSW TD5, Zambezi Silver
Post #446981 18th Aug 2015 6:23am
tasr12
Has anyone heard from/seen Airpusher or Stiff1 as I haven't had anything back from either?
Consequently still looking...thanks. 2002 110 CSW TD5, Zambezi Silver
Post #450724 31st Aug 2015 4:04am
Stiff1
Hi, still here, do not know why pictures did not go through to you, my apologies.
Another member has claimed the steps, if they do not follow through I will let you know.
Good luck.
Post #450736 31st Aug 2015 7:27am
Page 1 of 3 123>
