Home > For Sale & Wanted > [Wanted] 110 Side Steps - XS |
airpusher Member Since: 04 Sep 2011 Location: South Wales Posts: 364 |
Hey Tasr12,
I have a set I took off mine. Click image to enlarge The main body is fine but the outriggers have surface rust. Sadly I'm no where near Salisbury, I'm in South Wales though. I'm looking for about £90 for them. I've no idea about postage as they are big!! HTH 2006 Defender Double Cab- Zambezi Silver |
17th Aug 2015 8:07am |
tasr12 Member Since: 09 Jun 2013 Location: Dorset Posts: 228 |
HTH,
That's pretty much what I'm looking for. I may be able to get Bristol way this weekend/early next week if you happen to be coming across the bridge? Cheers. |
17th Aug 2015 10:11am |
Hey,
Sadly I'm not around over the weekend as it's my little ones birthday this week. If your not in a rush then I'm sure we could come to some arrangement. 2006 Defender Double Cab- Zambezi Silver |
17th Aug 2015 12:28pm |
That may wprk thanks. No particular rush other than wanting to get stuck in while I have the time! Have you still got the boots for steps?
Cheers. 2002 110 CSW TD5, Zambezi Silver 1995 110 CSW 300TDi - SOLD |
17th Aug 2015 12:44pm |
Boots? Bolts? If so yes, there is a bag attached with the bolts I'll have a check too and add any that look to be missing etc.
They go into rivnuts on the side of the chassis frame. I had to put them in on mine as they weren't present. 2006 Defender Double Cab- Zambezi Silver |
17th Aug 2015 1:23pm |
Apologies, meant bolts!
On my 300TDI they just bolted on using nuts and bolts, do you mean yours needed captive bolts on the chassis points? Cheers. 2002 110 CSW TD5, Zambezi Silver 1995 110 CSW 300TDi - SOLD |
17th Aug 2015 1:40pm |
To be honest they have sat in the garage for ages now so I can't remember.
They fitted very similar to this http://www.sidesteps.co.uk/fitting/defender_110_steps.pdf except the stays need to be bolted to the chassis rather than clamped as per those instructions. The holes were present but not the rivnuts. In the clamped photo just off to one side you can see the rivnut 2006 Defender Double Cab- Zambezi Silver |
17th Aug 2015 1:48pm |
Thanks for that - I'll be needing rivnuts then! 2002 110 CSW TD5, Zambezi Silver
17th Aug 2015 1:51pm |
Quite possibly!
I've read quite a few people didn't bother with the stays and when I first fitted them, till I got rivnut I didn't. They just counteract the swing when people stand on them. I may have some left from doing mine, I'll have look later. You may be luck and there may be some already present. 2006 Defender Double Cab- Zambezi Silver |
17th Aug 2015 1:55pm |
I pick up the TD5 on Thursday so will have a look then.
17th Aug 2015 2:20pm |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 596 |
Hi, if airpushers don't come off for you I have a set recently removed. All bolts present including a new set of rivnuts located in Truro, Cornwall.
One has a bit of a dent on the underside and a couple of spots where the powder coating has peeled otherwise are fine. Will eventually get round to listing them for about that money. |
18th Aug 2015 12:45am |
Many thanks. 2002 110 CSW TD5, Zambezi Silver
18th Aug 2015 6:23am |
Has anyone heard from/seen Airpusher or Stiff1 as I haven't had anything back from either?
Consequently still looking...thanks. 2002 110 CSW TD5, Zambezi Silver 1995 110 CSW 300TDi - SOLD |
31st Aug 2015 4:04am |
Hi, still here, do not know why pictures did not go through to you, my apologies.
Another member has claimed the steps, if they do not follow through I will let you know. Good luck. |
31st Aug 2015 7:27am |
