Home > Technical > puma2.2 diesel filter , some confusion
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
I have read a lot about the way to change the diesel filter on a defender with puma 2.2.
I even do the work on my defender one or 2 years ago.
I remember that I make some faults but luckily, it start ...
So, some questions !
- Did the 2.2 have a primary pump or not.
(have read somewhere that it have and turn only some seconds, I have to say that when I turn the key, I hear a noise which could be from a pump )
If yes, where it is and can we use it to purge the system.
- which connection is the one who is coming from the fuel tank, the male or female
Thanks for your help
Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #445636 13th Aug 2015 6:44am
munch90
with any fuel filter change its always best to filter first with clean diesel then fit it
just to keep air to a minimum when first started
Post #445640 13th Aug 2015 7:04am
Phil VM2.5
Hi,
less confusion ...
I did fil the filter with diesel and it start ...
But I did realise that I have a pump in the fueltank so it could be next time that I have only to change the filter and put contact and the pump will purge the system, we will see
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
1987 BMW GS80
Post #446693 17th Aug 2015 7:54am
