![]() | Home > Td5 > Groaning power steering |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
My td5 90 does it when turning left, even with a new power steering pump. Worth taking it to the dealer though as my 2015 110 was silent 2002 90 Td5 Station Wagon
THE DOCTOR Member Since: 11 Jan 2015 Location: North Yorkshire Posts: 31 ![]() ![]() |
My 64 plate has done it from the start when cold when spinning from straight to lock. Been in three or four times and no one has a clue what it is.
I know that I may be far from the cause but I've had to sort out my ex-wife's Fiesta with a very noisy PAS system. It was constantly getting air in and when switched off would spew out frothy fluid. What that came down to was the lad that had fitted a replacement pump was a little lax, I tightened the pressure pipe from the pump by a quarter turn and replaced a hose clip on the return. it works perfectly now. I'd be having a look at the tightness of all the pipe connections right up to the reservoir, even though it may not leak fluid it might be enough to allow air in, even within the steering box.
