Home > Puma (Tdci) > Gearbox levels
Eau02467
Gearbox levels
Hi all,
Just want to check I am not being stupid, decided to top up the axles gearbox etc today (did the main part of the service earlier In The month but took me a few weeks to get around to finishing the rest). Anyway started filling the gearbox and expected it to take a small amount but it took nearly 2.5 litres before the oil started to spill out of the filler hole! The gearbox doesn't have any leaks and I am guessing it has been this way since it left the factory, not impressed but before I go on a rant to dealer has anyone else come across this?
This was its first non dealer service as it has just dropped out of warranty
Edit - just saw the sticky on service of oils....looks like I have overfilled it....
Post #445893 13th Aug 2015 8:19pm
landy andy
Yep. Drain, and measure the amount you put in Thumbs Up
Post #445901 13th Aug 2015 8:29pm
rossy
yep 2.2 litres and not a drop more. That gearbox gets as hot as the engine in use and too much oil will damage the seals. Good luck - its a fiddly job but well worth the effort Thumbs Up
Post #446260 15th Aug 2015 7:25am
