Home > Wheels & Tyres > Tyre Rub 18" Boost Alloy Wheels 265/65/18 BF
maxlomax
United Kingdom 2010 Defender 110 2.5 TD SW Corris Grey
Hi,
I have just changed my wheels on my 2010 Defender 110 to a set of new 18" Boost gloss black alloy wheels fitted with 265/65/18 BF tyres.
On full lock the tyres rub, I have read that you can adjust the amount the wheels turn.
What's best, adjusting the turning amount or fitting spacers?
Any advise would be appreciated.
Post #445876 13th Aug 2015 7:26pm
Green Machine
If you want to maintain your turning circle then spacers would be your best option. Bear in mind though that the spacers might push the edge of the tyre out beyond the wheel arch (technically illegal) but will also cover the side of the truck in muck, which can get annoying. Dirt Defenders do seem to help with that problem though.
Adjusting the steering stops is the easier, cheaper solution but you may find yourself doing a lot more car park shuffling! 2005 Td5 | 90 Station Wagon | Tonga Green
Post #445889 13th Aug 2015 8:03pm
maxlomax
Hi, The turning circle is already bad so id say that spacers could be the option. The tyres look like they will still be within the arches.
How much time would it take a garage to adjusting the steering stops?
Are spacers easy and straightforward to fit.
thanks
Post #445895 13th Aug 2015 8:20pm
SailingTom
only 2 bolts one on each side of the front, you can do it yourself in 10 mins and spacers fitting is just taking one wheel off the the spacer bolting on then refit the wheel. both jobs are as quick and easy as you can get.
Hope this helps
Post #445898 13th Aug 2015 8:23pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Like SailingTom says - very easy to do either yourself - this is the nuts that needs adjusting, each one is just a 'stopper' for the opposite side when on lock, get someone to turn the steering wheel while you have a quick look underneath
From memory they are 17/19mm spanner size, they just need adjusting to stop the tyre rubbing on the radius arms....
Post #445908 13th Aug 2015 8:42pm
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
I'd be really interested in any members direct experience of spacers on the 18" Sawtooths.
I've considered doing it but not taken the plunge.
There seem to be a wide variety of makes/prices too, some very expensive.
Post #445915 13th Aug 2015 8:59pm
munch90
Deleted
Post #445931 13th Aug 2015 9:56pm
maxlomax
Hi, I have fitted 30mm spacers and it all running perfect now.
Post #448680 24th Aug 2015 11:54am
Barney12
Out of interest which ones did you fit?
Post #448682 24th Aug 2015 12:02pm
maxlomax
I have 18" boost alloys so I got these
http://www.ebay.co.uk/itm/111714461858?_tr...EBIDX%3AIT
Post #448683 24th Aug 2015 12:04pm
Barney12
Slightly showing my ignorance here.....
How do these work. Do I assume they come with longer bolts or do you bolt to the hub and then are they threaded for the wheel nut?
Post #448688 24th Aug 2015 12:46pm
The spacers are bolted to the hub using standard steel wheelnuts. The spacers are fitted with studs to which the wheels are then secured, using nuts appropriate to the wheels (alloy or steel).
It is the need to accomodate the first nuts and the heads of the setscrews which form the spacer's studs which make it impossible (or at least monstrously unsafe) for a spacer to be thinner than 30mm.
Post #448693 24th Aug 2015 1:36pm
