![]() | Home > Maintenance & Modifications > Wheel carrier or better hinges? |
Even many new Defenders I have noticed over the years come with a slight dent in the rear right hand quater panel where the standard wheel has either impinged on the rear light or the panel itself and pushed the panel in. Ultimately dependant on need/desire a wheel carrier IMHO is the only proven way of retaining the spare and transferring the load to the rear crossmember. They can be costly though. I too have aftermarket hinges but I don't think any of them profess to be load bearing upgrades. Due to the profound weight of my steel wheels and tyres I fitted a swing away as soon as I saw and procured the one I was after. A rear door strut (see link) I would say is also 'up there' as one of my best buys (speak to Brendan).
![]() Click image to enlarge http://www.defender2.net/forum/topic35644....door+strut If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
CarlS Member Since: 10 Apr 2007 Location: Probably near you Posts: 148 ![]() ![]() |
I'm just looking into this myself. Although I'm thinking I might put my spare on the roof rack if I can find a decent way of covering up the carrier holes in the back door. The spawn of AndrewS
2016 Defender 110 XS Station Wagon (Built on the last day, 59 from the end) - Dead 2016 Mini Countryman Cooper S All 4 2019 BMW R1200 GSA Rallye Sport |
There is NO one simple answer!
A lot depend on where and how you drive your vehicle. A couple of thousand miles a year pottering around on good surfaced roads then no you do not need either. ( Yesterday I saw a belter of a 110 TD5 on an 05 plate which had covered 6,000 miles from new, stored in a garage under a sheet etc) Planning on doing a few thousand miles on corrugated roads then that is a definite YES. Also depends on condition of rear door now. So have a good look at the inside of the door, check for play in the hinges, refurbishment kits are available quite cheaply. Think how you are likely to be using your Defender then decide what is best for you. Wheel carriers go from about �150 to over a grand. Brendan |
Barney12 Member Since: 09 Jun 2015 Location: South West Posts: 744 ![]() ![]() ![]() |
I've been through the same thought process and in the end went for the Nakatanenga from Brendan:
http://www.4x4overlander.com/product/nakat...-coated-2/ What swung it for me (no pun intended ![]() As K9F says the Naka... rear door strut is a great addition. Quick and easy to install. My only negative is that I now really fancy a NAS step but they won't fit with the Naka... carrier ![]() EDIT: See Brendan's post below. I've absolutely no idea what I'm talking about ![]() Last edited by Barney12 on 13th Aug 2015 4:41pm. Edited 1 time in total |
Tut tut Barney, where is the slapped bottom emoticons when you need it?
![]() The Nakatanenga wheel carrier will fit with the genuine NAS step. You may or may not have to trim a little bit of the rubber tread plate. For non genuine ones it is harder to say. If they are an exact copy no problem (apart from a little bit of rubber trimming) Here you go look here for photos of Nagatanenga wheel carrier and NAS step. We have sold a lot to Defender 2 forum members and typical comments made are things like well made, well engineered, easy to fit etc. Brendan |
Well
![]() ![]() I swear I had read on this very forum that they didn't fit. Right off to find a genuine NAS step supplier ![]() |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
Thanks for the replies.
I don't think I can stretch to a Naka one, maybe a Mantec one at best. I won't be doing many miles but I will go soft roading on the shoot etc and would prefer a carrier. It will have to wait for a few other essentials first though. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
cozz Member Since: 15 May 2013 Location: nottingham Posts: 547 ![]() |
i want one too
but I cant see the money in the NAKA ones, if I had one I could get a mate to make me one in stainless prob end up getting a mantec I guess |
