![]() | Home > Puma (Tdci) > AC vents in dashboard not working |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I know this could come across as condescending but have you twisted the dial around so that air is selected to blow out of those vents??
no electric blend motors on defenders , only manual flaps guessing cable that moves the flat has slipped its position |
expatRob Member Since: 24 Feb 2015 Location: Frankfurt Posts: 58 ![]() ![]() ![]() |
Roy: No worries, I appreciate the reply. You never know. I had that covered though. I am a new Owner.
Munch90: Thanks for the Education. I will open up the dashboard and look for a slipped cable. |
Well I pulled off the center console dash and saw that the vent selection nob just clicked to different positions and did not have manual flap wire connected to it.
Any thoughts on working with the blend motor ( I will have to find it first) Thanks, Rob |
NO blend motors on defenders , only cables and rods move the flaps , maybe cable has come right off or missing
how long have you had defender? did it ever work ? ( was cable missing when you brought it ) |
