Home > Puma (Tdci) > AC vents in dashboard not working
expatRob
Germany 2007 Defender 110 Puma 2.4 SW Tonga Green
I have a MY07 Defender, My AC works fine but I do not get any air coming out of the middle dashboard round vents. I believe the blend motor is bad. Does anyone have any advice and replacing it, fixing it etc.?
Thanks
Post #445678 13th Aug 2015 9:54am
Roy5695
I know this could come across as condescending but have you twisted the dial around so that air is selected to blow out of those vents??
Post #445681 13th Aug 2015 10:00am
munch90
Re: AC vents in dashboard not working
Thanks
no electric blend motors on defenders , only manual flaps
guessing cable that moves the flat has slipped its position
Post #445687 13th Aug 2015 10:10am
expatRob
thanks
Roy: No worries, I appreciate the reply. You never know. I had that covered though. I am a new Owner.
Munch90: Thanks for the Education. I will open up the dashboard and look for a slipped cable.
Post #445715 13th Aug 2015 10:48am
expatRob
MY07 does have Blend Motors
Well I pulled off the center console dash and saw that the vent selection nob just clicked to different positions and did not have manual flap wire connected to it.
Any thoughts on working with the blend motor ( I will have to find it first)
Thanks,
Rob
Post #446010 14th Aug 2015 10:17am
munch90
NO blend motors on defenders , only cables and rods move the flaps , maybe cable has come right off or missing
how long have you had defender? did it ever work ? ( was cable missing when you brought it )
Post #446015 14th Aug 2015 10:23am
