Home > Puma (Tdci) > engine problem
boiler
England 2010 Defender 110 Puma 2.4 XS CSW Keswick Green
engine problem
Using a lot of oil and not leaking on floor went to garage this morning . They checked the oil filler cap with engine running there was back pressure and also when he lifted dipstick then told me the 2.4 tdci engine as had it and I need a new one . I am new to the group
Any ideas guys
Post #444887 10th Aug 2015 3:18pm
munch90
any knocking ?
any blue smoke?
Post #444890 10th Aug 2015 3:29pm
boiler
No knocking or blue smoke and no loss of performance . Just using over 1litre of oil ever 600 miles
Post #444891 10th Aug 2015 3:32pm
munch90
how many miles on the clock?
Post #444896 10th Aug 2015 3:40pm
boiler
84k
Post #444899 10th Aug 2015 3:49pm
munch90
not lots of miles then , im surprised at you cant see any blue smoke with 1lt=600miles
Post #444904 10th Aug 2015 4:16pm
boiler
could it be a turbo issue or injector washers leaking oil where it should not .
I have no knowledge of cars . just love driving the defender
Post #444907 10th Aug 2015 4:18pm
munch90
turbo issue would be seals gone ,
seal gone on exhaust side then blue smoke and oil out of exhaust
seals gone on inlet side then blue smoke , running on own oil ( very high revs and you cant stop them without stalling or shutting off air supply )
they is talk on here of injector seals ( personally never seen one go ) , causing excessive crank case pressure which could push oil down breather pipe
if its running fine , then might be worth getting a set of washers fitted first , its not a long or hard job and shouldn't cost a fortune
maybe get a 2nd opinion
Post #444911 10th Aug 2015 4:27pm
K9F
Where did you take it? Is it a reputable garage? If not on the basis of a recommendation of good service in your area go take it for a second opinion. Irrespective if your engine "has had it" (so eloquently put!) they would explain why this is the case and where your oil is going. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #444914 10th Aug 2015 4:28pm
Canberra Man
Go with Munch90's suggestion, replace the injector seals.
I had exactly the same, including "your engine is shot mate".
Change the washers and problems sorted. Worth having them re-checked for tightness after 2 - 3 weeks.
Post #444929 10th Aug 2015 4:57pm
munch90
worth finding somewhere that can do a proper job and have a injector seat cleaner to use , as some will just fit new washers on top of crap down injector hole
Post #444930 10th Aug 2015 5:00pm
boiler
Thanks guys
Post #444939 10th Aug 2015 5:43pm
What year did the PCJ problem get sorted at source? I have a feeling that 2010 is possibly just old enough to suffer from it, which, if so, could indicate knackered pistons and bores and bearing damage throughout.
If this is suspected, check sump and filter for metal fragments and if necessary remove the head to inspect the bores. If the vehicle has a full LR service history LR may assist with the cost if it is this.
Post #444940 10th Aug 2015 5:51pm
HardCharger
2011 Defender 110 Puma 2.4 SW Stornoway Grey
I had the same issues with my 2.4 Puma needing a top off every so often, turned out to be a cracked turbo that was leaking oil into my air system. Replaced the turbo and cleaned out the air ways, so far, so good. Still have to work out on how the clean the EGR though.
I might look at my injectors next as indicated as there is still a bit of oil being eaten up but not as bad as before.
Post #445091 11th Aug 2015 6:59am
dgardel
Italy
boiler
check the injectors copper seals. If the seals are damaged, the engine sucks oil from there and you have backpressure if you remove the oil fill cap when running
Have you oil around the injectors on the cam cover? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #445099 11th Aug 2015 7:42am
