Home > Td5 > 2002 TD5 90 CSW Tow electrics.
Gareth
The towing electrics on my TD5 90 have corroded away at the plug, and whilst I could just fit a new plug, I have a new caravan with a 13 pin connection.
I could fit the normal 12N and 12S sockets, and use an adaptor to connect the caravan, but I think it would be better and neater to fit a 13 pin socket to the vehicle.
Does anybody know if the 13 pin electrics will plug in under the right hand rear wheel arch like the old 12N harness that I have just removed? or will I be into wiring mods to fit a 13 pin version? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #443199 4th Aug 2015 8:21pm
Martin
Site Admin
The 13 pin electrics do plug in, but there is a branch which goes forwards to the battery where a relay is mounted to generate the ignition feed for the 13 pin socket.
I've got 13 pin on the Puma but have not yet fitted the ignition branch Embarassed But I am not towing a tin tent just normal trailers Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #443229 4th Aug 2015 9:32pm
Gareth
Thanks Martin, that sounds easy enough. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #443231 4th Aug 2015 9:42pm
Martin
Site Admin
I realise this is teaching you to suck eggs, but the instructions are on TOPIX Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #443232 4th Aug 2015 9:44pm
Gareth
Good job I like eggs Wink 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #443240 4th Aug 2015 10:01pm
Martin
Site Admin
Having said that, for the Td5 part numbers (for a 90, YWJ500040) the instructions are not on TOPIX Embarassed Rolling Eyes  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #443441 5th Aug 2015 4:53pm
Gareth
Ok, saved me the bother of looking.
Anyway having found out the cost of the LR 13pin setup (130 quid), I think I will hack the plug off the one I have, and modify it onto a 13 pin plug which I can get for a fiver. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #443453 5th Aug 2015 5:10pm
Martin
Site Admin
I'd agree with you. All of the connections except the ignition are available in the rear wheel arch if you look hard enough Wink
Buy a Menber's or Maypole socket to get the best quality IMO.
I can recommend this seller: http://www.ebay.co.uk/itm/251391531952
Or a Maypole one cheap from Screwfix (order for store delivery): http://www.screwfix.com/p/maypole-mp129-13...80mm/48923  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #443460 5th Aug 2015 5:20pm
