Home > Maintenance & Modifications > Recaro Seats installed ! |
^^ Vinyl is not so pleasant in the summer, no? You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
10th May 2015 9:35am |
Eric,
On reflection perhaps not!.....Sweaty cleft...... Maybe the extra outlay is worth it after all. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
10th May 2015 9:47am |
Landydefender1 Member Since: 13 May 2015 Location: East Yorkshire Posts: 63 |
Why not just get some Saab seats?
14th May 2015 8:46pm |
Why are they Recaros? I used to have a Saab 900 2.3 and wouldn't entertain the idea of fitting the seats from that for any reason whatsoever in my Defender. Any pictures? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
14th May 2015 9:45pm |
AndyTunn Member Since: 10 Jan 2015 Location: Auckland Posts: 313 |
Great looking seats! I love the Moto-Lita wheel too...
Can you confirm, is this the 15" flat version? Thanks |
2nd Aug 2015 12:52am |
Vapeur33 Member Since: 28 Jan 2012 Location: Arcachon Posts: 8 |
I come back at the forum sorry for late answers :
- Yes, Recaro seats provided by Urban Truck have the back removable just as the standard seats. - The cheaper option for the Recaro are nice in summer, it's not vinyl. - And yes, the wheel is a 15" Motolita that I like very much. All in one, a very nice truck! 2,4 Puma 110 SW Light gray |
4th Aug 2015 7:04am |
yes I also put a spacer on mine for the same problem. it is sufficient 2 washers..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
5th Aug 2015 4:55am |
^^ So you lift the Recaros only from under the outer side rail, yes? Meaning you will be leaning very slightly to the inside, you are not really straight up any more? Is that due to the effect of having those Mud rails, or would you have that touching the side without those Mud rails also? Interesting, because in the SVX where Recaros are standard, they don't even come anywhere close to the outer sides trim. Seems that by using those Mud rails you are not getting the same effect of additional legroom versus standard seats, like you do have with the original seat fixings in the SVX.
Or, is this a problem not related to the Mud rails itself, but only to using them in a 90? I am not sure about this, but I doubt that the original SVX 90 SW had such a problem. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
5th Aug 2015 5:10am |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2035 |
Thanks dgardel, will try extra washers later.
5th Aug 2015 8:53am |
2 or 3 washers (4 - 6 mm thick) under the rail is equivalent to a shift of 2 -3 cm above Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
5th Aug 2015 9:35am |
