Home > Maintenance & Modifications > Recaro Seats installed !
Page 2 of 2 <12
ericvv
Post #422349 10th May 2015 9:35am
K9F
Eric,
On reflection perhaps not!.....Sweaty cleft...... Shocked Rolling with laughter Thumbs Up
Maybe the extra outlay is worth it after all. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #422350 10th May 2015 9:47am
Landydefender1
United Kingdom 2003 Defender 90 Td5 HT Rioja Red
Why not just get some Saab seats?
Post #423627 14th May 2015 8:46pm
K9F
^^^^Question
Why are they Recaros? I used to have a Saab 900 2.3 and wouldn't entertain the idea of fitting the seats from that for any reason whatsoever in my Defender.
Any pictures? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #423644 14th May 2015 9:45pm
AndyTunn
New Zealand 2008 Defender 90 Puma 2.4 SW Stornoway Grey
Re: Recaro Seats installed !
Great looking seats! I love the Moto-Lita wheel too...
Vapeur33 wrote:
Can you confirm, is this the 15" flat version?
Thanks
Post #442345 2nd Aug 2015 12:52am
Vapeur33
France
I come back at the forum sorry for late answers :
- Yes, Recaro seats provided by Urban Truck have the back removable just as the standard seats.
- The cheaper option for the Recaro are nice in summer, it's not vinyl.
- And yes, the wheel is a 15" Motolita that I like very much.
All in one, a very nice truck! 2,4 Puma 110 SW Light gray
Post #442952 4th Aug 2015 7:04am
DAZ110
Just fitted my Recaros in my new 90 that I had previously in my 110, but the top side near the headrest is rubbing on the side trim by the seat belt fixing. didn't have this happen in the 110. I do have the Mud rails under the seats. Any body else had this problem ? I was thinking of spacing the mud rails with washers to tip the seat away from the side trim.
Post #442989 4th Aug 2015 9:21am
dgardel
Italy
DAZ110 wrote:
IJust fitted my Recaros in my new 90 that I had previously in my 110, but the top side near the headrest is rubbing on the side trim by the seat belt fixing. didn't have this happen in the 110. I do have the Mud rails under the seats. Any body else had this problem ? I was thinking of spacing the mud rails with washers to tip the seat away from the side trim.
yes
I also put a spacer on mine for the same problem. it is sufficient 2 washers..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #443278 5th Aug 2015 4:55am
ericvv
^^ So you lift the Recaros only from under the outer side rail, yes? Meaning you will be leaning very slightly to the inside, you are not really straight up any more? Is that due to the effect of having those Mud rails, or would you have that touching the side without those Mud rails also? Interesting, because in the SVX where Recaros are standard, they don't even come anywhere close to the outer sides trim. Seems that by using those Mud rails you are not getting the same effect of additional legroom versus standard seats, like you do have with the original seat fixings in the SVX.
Or, is this a problem not related to the Mud rails itself, but only to using them in a 90? I am not sure about this, but I doubt that the original SVX 90 SW had such a problem.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #443279 5th Aug 2015 5:10am
DAZ110
Thanks dgardel, will try extra washers later. Thumbs Up
Post #443315 5th Aug 2015 8:53am
dgardel
Italy
Eric
2 or 3 washers (4 - 6 mm thick) under the rail is equivalent to a shift of 2 -3 cm above Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #443342 5th Aug 2015 9:35am
Page 2 of 2 <12
