Home > Puma (Tdci) > Gearbox oils |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 247 |
Thats what i've put in mine. 1953 80"
1987 mini city e 2011 90" |
3rd Aug 2015 7:20pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7878 |
T box is EP90 is it not?
gbox LR would have you believe is specific to them but you can get the same product elsewhere at about £45 for 5l. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
3rd Aug 2015 7:49pm |
personally I wouldn't put a thin full syn in transfer box
80/90 gear oil would be my choice in transfer 75/90 full syn in gearbox |
3rd Aug 2015 7:56pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2395 |
Use GL-4 rated oil for the gearbox. I do not recommend GL4/GL5 oils for gearboxes. GL-5 is not backwards compatible for synchros, but it is for "gears".
And by the way the LT230QRS TBOX can be filled with synth 75W/90 (GL-4 or GL-5) Puma 110" SW ............................................................. Earth first. Other planets later |
3rd Aug 2015 8:41pm |
