Home > Maintenance & Modifications > help - mantec load lugga |
jaydt Member Since: 31 Aug 2013 Location: west midlands Posts: 36 |
Give mantec a call direct and ask for tecnical department i spoke to a nice chap who emailed me the instructions and a little video. i fitted mine two weeks ago to my 110 s/w and was pulling my hair out also. had to take all side trim out and became self explanitory. must admit that it came with only half the nuts and bolt required tho. hope this helps.
1st Aug 2015 5:19am |
TooTall Member Since: 10 Jul 2012 Location: Fens Posts: 504 |
^^ What he said ^^
I had to do exactly the same thing, so I feel your pain TT "Ease your worries, Clear-up your woes, Go into your garage & put stuff into rows." |
1st Aug 2015 6:48am |
josefk Member Since: 09 Jun 2014 Location: lincolnshire Posts: 113 |
Hi TT,
do you have this fitted in your new 90? would you have a pic you don't mind sharing? i'm indirectly in contact with mantec and there is a possibility i have a bit of a friday afternoon bit of trim fitting that is baulking the bracket...i wouldn't mind being able to check it before admitting defeat over something that should be very straightforward. Cheers Joe |
4th Aug 2015 10:57am |
