Home > Maintenance & Modifications > help - mantec load lugga
josefk
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
hi, i wonder if anyone can help me?
i've bought a mantec load lugga and it comes without instructions. it ought to be simple but i think i'm going mad because while i was told the upper brackets are handed neither "left" nor "right" bracket seem to make any sense when offered up to the roof rail and the bolts and fittings already there.
i have a puma 90 sw and the only way i seem to be able to get two bolts on the load lugga is with it rammed all the way forward in the rear load space which makes no sense.
if anyone had a hint or a pic of one of these fitted in a 90 so i can get a clue of where it ought to sit then i would much appreciate it.
cheers
joe
Post #442047 31st Jul 2015 8:55pm
jaydt
2011 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Give mantec a call direct and ask for tecnical department i spoke to a nice chap who emailed me the instructions and a little video. i fitted mine two weeks ago to my 110 s/w and was pulling my hair out also. had to take all side trim out and became self explanitory. must admit that it came with only half the nuts and bolt required tho. hope this helps.
Post #442090 1st Aug 2015 5:19am
TooTall
United Kingdom 2004 Defender 90 Td5 HT Tonga Green
^^ What he said ^^
I had to do exactly the same thing, so I feel your pain Big Cry
TT "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows."
Post #442099 1st Aug 2015 6:48am
josefk
Hi TT,
do you have this fitted in your new 90? would you have a pic you don't mind sharing?
i'm indirectly in contact with mantec and there is a possibility i have a bit of a friday afternoon bit of trim fitting that is baulking the bracket...i wouldn't mind being able to check it before admitting defeat over something that should be very straightforward.
Joe
Post #443024 4th Aug 2015 10:57am
