Home > Puma (Tdci) > Long Range Fuel Tank
Monreith boy
United Kingdom 2014 Defender 110 Puma 2.2 USW Firenze Red
I am thinking of getting a long Range fuel tank from Britpart.
Does anyone use one and how do they find it.
Post #441812 31st Jul 2015 12:06am
leeds
No idea about Britpart fuel tank, do not know who makes it.
Play a game of 20 questions with me as the choice of long range fuel tanks is not 100% straight forward.
90 or 110?
Original chassis or replacement chassis?
Standard suspension or twin shocks?
Seat belts in rear tub?
Original fuel tank?
Plastic for 90 or Ali, mild steel or stainless for 110
110 wing tank single or double skinned bottom?
Larger main tank is possible but then what towing equipment do you want to use?
On one of our 110 we had 170 litre fuel capacity, you can go up to about 330 litres on a 110! So what fuel capacity is required?
Brendan
Post #441823 31st Jul 2015 4:14am
Penguin
Belgium 2015 Defender 110 Puma 2.2 HT Chawton White
I would go for the frontrunner one. From all the parts I have from Brit Part, not one is of good quality. Ok for light protection and other small addons, but for a fuel tank I'd sure don't want to take any risk. 28/02 - Loss of a good friend...
In a time of chimpanzees, I was a penguin.
Post #441826 31st Jul 2015 5:20am
Monreith boy
The Britpart gives an extra 45 Litres.
I do a lot of motorway driving and thought it would be beneficial to have a bigger tank.
I am driving a year old 110 Utility.
Post #441853 31st Jul 2015 7:57am
bittersweet
2009 Defender 110 Puma 2.4 USW Santorini Black
There are good reasons why we ask 20 questions Razz
Think very carefully if you are likely to fit rear bumperettes or a single pivot wheel carrier in the future.
A wing tank severely hampers the access to fitting these once it is fitted. You do not really want to be dropping a wing tank to fit a wheel carrier two weeks after fitting the tank.!
We can supply various long range tanks from 120 litre main tanks which have implications to towing equipment and tank guards
We can also supply 45 litre flow through fuel tank as well note comment about wheel carrier.
These are available in mild steel or stainless steel .
For normal UK road use would suggest mild steel and single bottom
Brendan www.4x4overlander.com
Post #441863 31st Jul 2015 8:56am
Monreith boy
Thanks for the advice.
Not going to bother with the extra tank.
Far to complicated!!!!
Post #443560 5th Aug 2015 9:37pm
Penguin
with 2 persons, just under 4 hrs for the Frontrunner. Straight forward job.
Hardest part is fitting the filling tube. 28/02 - Loss of a good friend...
Post #443595 6th Aug 2015 4:49am
