![]() | Home > Puma (Tdci) > Long Range Fuel Tank |
No idea about Britpart fuel tank, do not know who makes it.
Play a game of 20 questions with me as the choice of long range fuel tanks is not 100% straight forward. 90 or 110? Original chassis or replacement chassis? Standard suspension or twin shocks? Seat belts in rear tub? Original fuel tank? Plastic for 90 or Ali, mild steel or stainless for 110 110 wing tank single or double skinned bottom? Larger main tank is possible but then what towing equipment do you want to use? On one of our 110 we had 170 litre fuel capacity, you can go up to about 330 litres on a 110! So what fuel capacity is required? Brendan . |
Penguin Member Since: 08 Dec 2014 Location: Tienen Posts: 247 ![]() ![]() ![]() |
Monreith boy Member Since: 30 Jul 2015 Location: Glasgow Posts: 6 ![]() ![]() ![]() |
The Britpart gives an extra 45 Litres.
I do a lot of motorway driving and thought it would be beneficial to have a bigger tank. I am driving a year old 110 Utility. Cheers |
bittersweet Member Since: 29 Apr 2010 Location: Yorkshire Posts: 20 ![]() ![]() |
There are good reasons why we ask 20 questions
![]() Think very carefully if you are likely to fit rear bumperettes or a single pivot wheel carrier in the future. A wing tank severely hampers the access to fitting these once it is fitted. You do not really want to be dropping a wing tank to fit a wheel carrier two weeks after fitting the tank.! We can supply various long range tanks from 120 litre main tanks which have implications to towing equipment and tank guards We can also supply 45 litre flow through fuel tank as well note comment about wheel carrier. These are available in mild steel or stainless steel . For normal UK road use would suggest mild steel and single bottom Brendan www.4x4overlander.com |
Thanks for the advice.
Not going to bother with the extra tank. Far to complicated!!!! Cheers |
