Home > Maintenance & Modifications > Fuel pump interchangeability |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 556 |
I think the only difference is the fuel level sensor which can be easily swapped over.
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
27th Jul 2015 12:49pm |
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 |
They are interchangeable, as said the sender is different. Someone fitted a Def one in my Disco, which is why the light comes on with a mere 40L left....... At least I should never run dry!
27th Jul 2015 6:41pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Got a disco one in my 90, just change the float and float arm on the sender and all works as it should 2002 90 Td5 Station Wagon
27th Jul 2015 7:31pm |
Crs90 Member Since: 08 Jul 2015 Location: In my excavator Posts: 82 |
Thanks for the help
Chris. |
27th Jul 2015 7:39pm |
