Home > Puma (Tdci) > Intermittent 'Clonk' pulling away/stopping
Jim_Bean
Guys,
Quick question before going ahead and replacing the A Frame ball joint. My MY13 110 with 29k on it has developed a really nasty metallic clonk. This happens when slowly coming to a stop or when pulling away. It is a horrible sound and the 'clonk' can be felt throughout the vehicle.
The strange thing is that the next day its fine, nothing. It can be fine for a few days and then suddenly its back. A horrible thud/clonk/crunch when stopping, turning slowly or pulling away from a standstill.
It happened the first time a few weeks ago. I thought it was a wheel bearing to start with. Both rear bearings are fine. The props seem fine (no play that I can see), springs and shocks 'seem' OK.
Having looked through the forum it seems that the A frame ball joint could be a likely culprit, but why the intermittent nature?
Is there anything else I should check or any other known failures?
Also, the handbrake light now comes on, again intermittently, when stoping or slowly going down a hill. I think the light has a dual purpose of 'handbrake on' and 'low brake fluid'. I've checked the fluid levels and they seem fine. I don't think the handbrake is sticking - its not hot after a long journey and I can coast without any resistance.
Any ideas?
Post #440677 27th Jul 2015 12:51pm
Rear radius arm bushes Whistle
Post #440679 27th Jul 2015 1:00pm
or handbrake drum Very Happy
Post #440681 27th Jul 2015 1:21pm
Grenadier
Does a whistle mean 'expensive' whilst the smiley means 'no problem' or 'DIY'.
What would this one mean Evil or Very Mad Censored Thud
Rolling with laughter Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #440683 27th Jul 2015 1:24pm
They mean that jim_bean's truck is outside the office window, next to mine and we went out have a look!! Laughing
I'd already suggested the bushes = Whistle
and after rocking the motor back and forth by the wheel, the handbrake drum clunks = Very Happy
So it'll get stripped on Wednesday...though we can't re-produce the clunking noise when driven...typically.
Post #440690 27th Jul 2015 1:36pm
Jim_Bean
Yep - handbrake is the most likely contender at the moment.
Still odd that it only happens every few days. Also only seems to happen when its raining! Although could be a total coincidence.
Post #440692 27th Jul 2015 1:43pm
steve E
Wales
I had this with the hand brake drum and it would only show after about 20 miles or so.
had it replaced under the used car warranty scheme.
Post #440695 27th Jul 2015 1:59pm
Jim_Bean
Did you get the brake light illuminating as well as the clonk?
Post #440696 27th Jul 2015 2:00pm
steve E
Wales
I didn't get the brake light and it was on my 2.4 truck cab
It only happened when slowing down at low speeds once driven for a while.
On a short run it never happened.
when it did happen you could feel it through the floor
Post #440697 27th Jul 2015 2:31pm
Jim_Bean
It does sound similar. Hopefully the problem will be easy to spot once I have the prop and handbrake drum off!
Post #440698 27th Jul 2015 2:36pm
Re: Intermittent 'Clonk' pulling away/stopping
Jim_Bean wrote:
... the handbrake light now comes on, again intermittently, when stoping or slowly going down a hill. I think the light has a dual purpose of 'handbrake on' and 'low brake fluid'. I've checked the fluid levels and they seem fine. I don't think the handbrake is sticking - its not hot after a long journey and I can coast without any resistance.
Any ideas?
The most likely reason for this is that although the fluid level is up to the MAX mark, it still isn't high enough to stop the light coming on when the fluid surges to the front of the reservoir whilst the brakes are applied. On my Defender, I have to have the fluid level right up to the bottom of the reservoir filler neck in order to avoid exactly the behaviour you describe.
Mine was OK normally, but if you braked hard, or if you braked going downhill, the combined surge was enough to illuminate the warning light. I topped the level up and it hasn't happened for 150k miles since.
Post #440699 27th Jul 2015 2:36pm
Jim_Bean
Thanks Blackwolf. I'll top it up to get rid off the light warning coming on under braking.
I'll check the handbrake assembly though to see if can locate the cause of the 'clonk'.
Post #440702 27th Jul 2015 2:41pm
