Home > Off Topic > phone sat nav |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6300 |
before you all shoot me down in flames ......I'm getting another Blackberry (Passport)....
but the question is this; I have no issues in using this in the UK as a sat nav BUT.... how will I get on using this in Europe (Spain / France) without incurring bills (or at least big ones) ? cheers Wayne |
22nd Jul 2015 1:30pm |
Spookytooth Member Since: 19 Jan 2014 Location: Lincolnshire Posts: 202 |
I believe the Passport has gps which does not require wi fi or roaming charges, just need to take the phone charger
http://docs.blackberry.com/en/smartphone_u...923117.jsp |
22nd Jul 2015 4:10pm |
It does have gps but I think it requires the network to get the route in the first place?
22nd Jul 2015 6:21pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2656 |
Get an app that has the mapping data stored locally and then it'll just work like a traditional satnav.
22nd Jul 2015 7:04pm |
Buy a proper sat nav , you tight git
22nd Jul 2015 7:51pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
CoPilot is a great Sat Nav app for phones (and tablets).
You download the maps (all of Europe in my case) at home then you don't need any data connection while using the app. Not sure if its available for Blackberry though. cheers simon Edit: just checked their site and it seems no Blackberry... http://copilotgps.com/uk/ |
22nd Jul 2015 7:53pm |
RustyM Member Since: 28 Oct 2013 Location: Africa/The Med Posts: 222 |
Mapfactor Navigator is a free application, you can download the whole world and it is based on open street maps so all free, unless you buy the TomTom maps for it. http://navigatorfree.mapfactor.com/en/download/ well worth a look 90 & Wolf
110 XS Previously owned SI SII SIIa SIII & Light weight (air portable) |
22nd Jul 2015 8:06pm |
Buz Member Since: 24 Jan 2014 Location: Forest of Dean Posts: 238 |
Used co-pilot for the 1st time this weekend....very good for a freebie....it also monitors traffic levels on your route and advises you if you need to re-route (this probably uses a bit of data though) |
22nd Jul 2015 9:20pm |
pumaxs Member Since: 18 Jul 2012 Location: Bath Posts: 180 |
I've got Navmii satnav loaded onto my 4g + wifi iPad Mini, and that worked well in France.
I've downloaded maps for UK&ROI, France + Spain, which are connected, so you can plan a route across France & into Spain, with waypoints. Their maps also work well offline, contain decent levels of detail, & will get you back on route if you take a wrong turn. Whilst Google Maps allows you to save offline maps, I found that it sometimes lacked detail at junctions, which made it difficult to orientate myself and make the correct turn. It also won't direct you back on route - You will just see the displayed route & your locating arrow floating about to the side. As a final thought, I would suggest that you still obtain + carry paper maps for the areas that you intend to visit, as satnav is not infallible. Michelin's "Grands Itineraires France 2015" is brilliant for navigating across France, as it only shows the principal roads that you will need. Their 1:150,000 maps for France, and 1:250,000 maps for Spain, are also great. Waterstones carry a good range in their UK stores. The "Institut Geographique National" (IGN) 1:25,000 maps of France really get into the finer detail. These are readily available in French service stations & supermarkets. Hope this helps. '57 Defender 110 XS Station Wagon 2.4tdci |
23rd Jul 2015 7:33am |
I use Here Maps, work really well for offline mapping in the UK (it does abroad too)
23rd Jul 2015 12:35pm |
thanks guys - another job for the weekend now I've got the phone.
munch90.....can't afford a proper satnav as all my money has gone on the motor ! |
31st Jul 2015 12:24pm |
