Home > Maintenance & Modifications > Puma electric window problems |
Wires in the rubber tube between the body and door
21st Jul 2015 8:26pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20497 |
As above, broken wire with on / off poor contact.
Should be able to visibly see it, if not continuity test. Will need replacing. |
21st Jul 2015 10:49pm |
Defpuma Member Since: 10 Feb 2013 Location: Kent Posts: 84 |
Cheers peeps. Will have a look this morning and see if I can find anything.
22nd Jul 2015 5:31am |
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 244 |
The loom is available as a spare part or you could cut and solder.
2 x Plugs are located in the bulk head side, and you can remove from central locking and window motor. mine were full of rust and had snapped inside the sheave. "Rafiki" 2007 110 STW - Rolling rebuild. |
22nd Jul 2015 1:33pm |
