Home > Maintenance & Modifications > Puma electric window problems
Defpuma
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Strange thing happened today. When the drivers side door is shut the drivers side electric window goes up and down as normal - when the door is open it won't work at all. The passenger side still works like this either with the door open or shut? Any ideas? It is just one of those little pain in the backside things that annoy you after a while!! Any advice much appreciated!!
Post #439433 21st Jul 2015 8:23pm
munch90
Wires in the rubber tube between the body and door
Post #439436 21st Jul 2015 8:26pm
As above, broken wire with on / off poor contact.
Should be able to visibly see it, if not continuity test.
Will need replacing.
Post #439490 21st Jul 2015 10:49pm
Defpuma
Cheers peeps. Will have a look this morning and see if I can find anything.
Post #439495 22nd Jul 2015 5:31am
Cold_n_Wet
Norway
The loom is available as a spare part or you could cut and solder.
2 x Plugs are located in the bulk head side, and you can remove from central locking and window motor.
mine were full of rust and had snapped inside the sheave. "Rafiki" 2007 110 STW - Rolling rebuild.
Post #439610 22nd Jul 2015 1:33pm
