Home > Technical > How to tell if you've a 36 or 48 Spline Steering Wheel
RRUK
Found this helpful page on the net.
http://www.web-rover.co.uk/nav.php?p=articles/steeringwheels 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #439280 21st Jul 2015 9:29am
Unfortunately it's been proven again and again that although that link is correct in the majority of cases, the reality is that LR chopped and changed and the only sure way of checking is to remove the wheel and count splines
Post #439294 21st Jul 2015 10:39am
RRUK
Which is actually quite hard to do - you go goggly eyed staring at them!
 2016 D4 HSE
Post #439300 21st Jul 2015 11:39am
JimC
United States 2007 Defender 130 300 Tdi HCPU Arles Blue
Press a chunk of clay into it and count by poking the splines.
Post #439363 21st Jul 2015 2:54pm
Once you get to 38 stop if there are more cause it will be a 48 if you get to 38 and there's no more splines you have a 36 Thumbs Up
Post #439372 21st Jul 2015 3:42pm
dailysleaze
Count the ridges and valleys of the splines then divide by 2
Post #439425 21st Jul 2015 8:11pm
mickygee
Australia 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
count the ridges, then multiply by 4, then halve that number, and then halve again
Post #439493 22nd Jul 2015 3:42am
nitram17
Buy two steering wheels one 36 & one 48......one will fit!
Post #439509 22nd Jul 2015 7:37am
