Home > Td5 > please help!!! gears |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Don't worry about it my last Td5 was like that for over 270,000
If it stops leaking you know it needs topping up..... seriously though, do you know what oil is in it? some seem to like MTF and some like ATF might be worth a change. Won't cure your leak though. |
28th Oct 2010 6:04am |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Sadly, they're all like it.
Had to replace mine after just 30,000 miles - Shot bearings! |
28th Oct 2010 8:58am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
My original box (04reg Td5 90) lasted 120thou miles, with the help of Difflock oils in the later stages. The next FOUR boxes have lasted a very short time
Andy |
28th Oct 2010 7:55pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8033 |
my '99 Td5 R380 did 105k miles when i had it with no problems. ran it on MTF. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
28th Oct 2010 8:43pm |
Was that "original" or "recon" Andy |
28th Oct 2010 8:46pm |
Original - now running with an Ashcroft re-con. |
28th Oct 2010 9:02pm |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 |
Landy Andy,
Is that 4 boxes and counting or 'hopefully' now sorted Steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
28th Oct 2010 9:27pm |
5 gear boxes and 4 transfer boxes, but needs to go back for another trans box as have a noise still.
But at least this gearbox is "good", shame that I have the trans box noise as it very nice to use, but noise = probs, and my warranty is running Andy |
30th Oct 2010 10:06am |
