Home > Maintenance & Modifications > Defender Air Conditioning fan switch |
resister pack for the fan speeds burnt out , quite common on all cars
think its down in the wing corner on the fan housing |
19th Jul 2015 11:41am |
Aymn7 Member Since: 19 Jul 2015 Location: SUDAN Posts: 5 |
Thanks
Do I need to dismantle the whole air conditioning kit ? |
19th Jul 2015 11:45am |
no I THINK its under the bonnet right in the corner on the side of the heater blower motor housing
https://s3-eu-west-2.amazonaws.com/i.hubnu...2349fe.jpg Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
19th Jul 2015 11:54am |
Very useful information,especially the wiring diagram
Thanks a lot |
19th Jul 2015 7:32pm |
Any luck fixing it ?
26th Jul 2015 6:36pm |
I could locate the resister pack thanks.
However I want to fix the blower, it works on full speed but it is noisy. I suspect the bushing or bearings. Thanks for your care Ayman |
27th Jul 2015 7:14am |
might be worth checking there is nothing in the blades like leaves etc and throwing fan out of balance that could make it noisy
if there is , it can damage the resistor as the restricted air flow doesn't cool the resistor causing it to burn out so there is a chance the problems are linked together |
27th Jul 2015 8:37am |
