Home > Maintenance & Modifications > Defender Air Conditioning fan switch
Aymn7
The A/C fan switch has 3 positions : low -mid-Hi .Low was not working in my Defender 110 .Two days ago I heard a noise coming from the fan and the A/c stopped suddenly when it was in the mid position.Now the switch works only in the Hi position.
I checked the fuse box but there is no separate fuse for the switch.
what is the solution ?
Ayman
Post #438868 19th Jul 2015 10:47am
munch90
resister pack for the fan speeds burnt out , quite common on all cars
think its down in the wing corner on the fan housing
Post #438880 19th Jul 2015 11:41am
Aymn7
Thanks
Do I need to dismantle the whole air conditioning kit ?
Post #438881 19th Jul 2015 11:45am
munch90
no I THINK its under the bonnet right in the corner on the side of the heater blower motor housing
https://s3-eu-west-2.amazonaws.com/i.hubnu...2349fe.jpg
Post #438883 19th Jul 2015 11:54am
Aymn7
Very useful information,especially the wiring diagram
Thanks a lot
Post #438950 19th Jul 2015 7:32pm
munch90
Any luck fixing it ?
Post #440497 26th Jul 2015 6:36pm
Aymn7
I could locate the resister pack thanks.
However I want to fix the blower, it works on full speed but it is noisy.
I suspect the bushing or bearings.
Thanks for your care
Ayman
Post #440588 27th Jul 2015 7:14am
munch90
might be worth checking there is nothing in the blades like leaves etc and throwing fan out of balance that could make it noisy
if there is , it can damage the resistor as the restricted air flow doesn't cool the resistor causing it to burn out
so there is a chance the problems are linked together
Post #440597 27th Jul 2015 8:37am
