![]() | Home > Puma (Tdci) > Urgent help! no power after new engine installation! |
JOE_130 Member Since: 26 Nov 2014 Location: Chelmsford Posts: 105 ![]() ![]() ![]() |
I'd insist on an injector change to 2012 level parts or try flashing your ECU with an "as built" map from a 15m/y vehicle. I've seen problem running like this when injectors were characterised for "pre globalised" engines. If Ford have made any changes to the injectors since 2012 (very likely) your 2012 level software on your ECU won't be electrically driving 2015 injectors correctly.
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 ![]() ![]() ![]() |
Just rebuilt my 2009 2.4 and had a similar issue - a change of injectors cured the problem.
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 236 ![]() ![]() ![]() |
The injectors coused indeed the problem..
Everything solved now.. Dealer (the Adventure Den Bosch, Netherlands) did a good job! Cheers Q. |
