Home > Puma (Tdci) > Heater door mirrors |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 |
They dont take much current.
The heated rear window supply is 20A. Possible to splice into the heated rear screen cable and fit an in line fuse, according to the diagram the + supply to the HRW is white & black. |
26th Oct 2010 7:40pm |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
HI bosun,
where did you get the elements from? |
28th Oct 2010 11:03am |
You can get the elements from eBay, cost about £17 for the pair.
Bit of a fiddle fitting the, devon 4x4 did a write up on the subject. I ran the cable down the arm and base so it cant be seen. Works a treat now. |
28th Oct 2010 11:40am |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 |
HI bosun,
where did you get the elements from? Hi Nicks, Got them from Scorpion when they were in business. Fitted a treat on my TD5, just haven't got around to fitting them on the TDCi yet. Just thought the heated rear window route might be easier. Used a switch in the spare aperture in the centre console before. Took some time routing the cables and connecting to the LR switch. Bosun |
28th Oct 2010 12:13pm |
What about conecting them so they are on constantly with ignition. The ones on the wifes Audi are on all the time, keeps the rain of them.
28th Oct 2010 12:16pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Hi All,
The Devon 4x4 Guide has gone. Well I haven't been able to get to it. Says " File no longer on server". How do you get the wire into the cab? Any advice or pictures would be much appreciated. |
29th Oct 2010 5:47pm |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
Hopefully this guide works
http://la7dja.org/defender/mirror-heating/ |
29th Oct 2010 5:55pm |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228 |
Thanks . I'm planning to do this mod also, on both my Td5 and Puma Defenders . Now I have to source those heating elements |
1st Nov 2010 9:12am |
Ive fitted both heated mirrors onto my 90, the hardest part is feeding the cable through the bulkhead and through the spring part on the mirror.
1st Nov 2010 12:16pm |
kljw Member Since: 23 Jan 2009 Location: Edinburgh Posts: 265 |
Hi
do you have pictures of how you any of you completed the task. i have downloaded the link info, but an interested in seeing how you chaps got on. thinking of doing this to mine. Cheers keith puer claudius |
7th Feb 2011 1:23pm |
i feed my cables behind the front door seals and connected striaght to the heated front screen terminals.
7th Feb 2011 3:50pm |
