Home > Puma (Tdci) > what springs will a 07 xs 90 have as standard
munch90
heavy duty ? standard ?
Post #436839 10th Jul 2015 9:17am
K9F
Heavy Duty. Thumbs Up
Munch my 08 has heavy duty and all the XS of that era were advertised as having HD suspension as standard. I believe later this option was no longer offered.
I am unsure of this last fact but was lead to believe the HD suspension gave you a 1" lift over non HD springs. Hope this helps. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #436844 10th Jul 2015 9:35am
munch90
thanks k9f . thought I remembered right about h/d suspension on xs
mine does seem a bit higher then most ive seen , so could be the 1 inch extra
but it does seem a bit harsh to drive , so what springs to fit ? cant go any higher , don't really want it any lower either ! ( maybe a bit as I could space up to get height right )
new h/t springs ?
Post #436845 10th Jul 2015 9:43am
K9F
Suspension can be an emotive issue. What suits one doesn't suit another. I considered a 'lift' four years ago and rather than 'bushing' radius arms, castor angles, turrets and all sorts of bits 'n' bobs were thrown into the mix. In the end I decided it was a 'wish' rather than a 'must' as I was relatively happy with the standard HD setup together with my own driving style and needs.
Still on the standard setup nearly 5 years later and still happy. Is it something you really 'need' or are you 'tinkering?' (No offence meant or implied) Just asking if you really need to mess with it?
Bow down Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #436850 10th Jul 2015 9:59am
munch90
tinkering I think is more like it ! (think I might have caterhamism )
yes put up with it and not had any problems in 7 odd years , so might just stick with it Rolling Eyes
Post #436852 10th Jul 2015 10:11am
K9F
Thumbs Up
Fully understandable....usually with me it's my week off between shifts, money to burn and all the job list with regards to household chores done and dusted! Then what? I know I'll go tinker a little.......
Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #436858 10th Jul 2015 10:44am
No need for HD springs unless you tow heavy trailers or for example have a very heavy bumper and winch or internal load.
D44 used to do some nice Eibach springs which were softish, not sure if they still do though.
Post #436867 10th Jul 2015 11:33am
munch90
yes got a 3.5t ifor tiltbed , so h/d handy for that Thumbs Up
just been out in it , and its not bad really at all
as k9f says got a bit of time so just making things up to change Rolling with laughter
Post #436906 10th Jul 2015 1:38pm
Yes, I'd imagine so or the Landy would get nose high wouldn't it.
I'm on the post 1997 licence so do not have B+E licence category so only tow light.
Post #436908 10th Jul 2015 1:44pm
