Home > My Defender > Kiwi Defender
Page 2 of 5 <12345>
AndyTunn
New Zealand 2008 Defender 90 Puma 2.4 SW Stornoway Grey
RDX rules!
Fitted the RDX LED upgrade light set today. Oh the luxury of not having the trailer light flash when you indicate! That makes them worth the purchase price on its own!
I want to LED-ize the whole car eventually, but don't think I'm going to be able to justify the $1000+ price tag for headlights so I'll probably follow the Crystal / Osram Nightbreaker / Boomslang loom path instead.
Post #403229 1st Mar 2015 7:49am
AndyTunn
90 SW storage
Finally completed (just about) my removable "storage solution" for the back of the 90. After a couple of trips with the fold-up seats in place I was getting frustrated by (a) the award storage space and (b) the lack of any where to put things "out of sight". Having worked out that seat removal is an easy 15-minute job I decided that the best option was a removable shelf which would span the wheel arches and provide a flat load bed and a discreet gap underneath for items best kept away from view.
The platform is simply 18mm ply cut to fit, with a four captive bolts that can be secured from underneath the wheel arches. I've cut the platform in 2 to make it a bit easier to handle, and there is a simple peg and hole arrangement between the two under the floor mat to keep them lined up.
The front section has cargo tracks installed to help with load management and to hold down the rubber checker-plate floor mat.
Now I just need to work out some form of dog-guard arrangement. Even though there will be strapped down boxes behind the front seats I'd like some further protection for me and her in case the worst happens. I'm wondering about a webbing cargo net with some suitable anchor points at roof level? I've seen these ones...
http://rocknroad4x4.com/shop/load-barrier-cargo-net-defender/
Does anyone know of any others?
Post #424340 18th May 2015 12:56am
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
We have the 2-piece dog LR guard behind the front seats (no bulkhead like yours) and it works really well. You can strap all sorts of stuff to it. Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #424880 19th May 2015 7:51pm
AndyTunn
A milestone
Today on the way home...
Post #431553 17th Jun 2015 8:12am
AndyTunn
DRLs, and other lighting matters
Latest mod: Hella DRLs and the Boomslang loom. I didn't take any "in progress" shots (I don't think my workmanship is that photo-worthy!) but here's the end result...
Top left: How the completed front end looks - RDX LED indicators and position lights, crystal headlight + Osram nightbreakers, flush-mount DRLs on the bumper. I did think about mounting them on the headlight surround but got a bit put off by the thought of trying to connect it all up behind the headlight bowl.
Bottom left: The lights are surface mount, but only 11mm deep.
Top right: I used a DRL "smart controller" relay, also from Hella, mounted in the passenger seat box. The +ve cables for the DRLs, and the feed wire from the position light, run forward to the nearside wing in loom tube cable tied to the chassis. The +ve feed for the Boomslang loom also runs through the same tube.
Bottom right: In the nearside front wing the DRLs connect to the positive feeds from the relay using waterproof connectors, so I can remove them / the bumper etc. without having to pull the whole thing apart. The earth wires from the connectors run out into this space behind the grill where I've used the radiator mounting bracket as an earth point.
Post #435841 5th Jul 2015 4:09am
AndyTunn
Calling photoshop pro's
I'm considering some minor changes - part cosmetic, part practical - and would like to see how they look before I proceed.
I'm thinking:
Stage 1 - anodise or powder-coat the chequer plate black.
Stage 2 - stage 1 plus tint the rear windows (sliders, rears, alpine)
Stage 3 - stage 2 plus spraying the roof and wheel arches black
If anyone who is a whizz at PS and has got 10 minutes to spare wants to have a go at mocking up these changes on the photo below I'd be eternally grateful! (I'd even go as far as to buy you a beer, but you'd have to come to New Zealand to collect it!!)
Post #436815 10th Jul 2015 6:09am
mk1collector
I'm no good with computers but to give you a rough idea I've got a before and after of my 110 on which I've done everything but the arches. I think it makes a massive difference Thumbs Up
 Ray
My build thread
Post #436832 10th Jul 2015 7:47am
AndyTunn
Thanks for posting those shots Ray. You're right - it does look a lot better.
PS I've just re-read the story of your defender and the many improvements you've made - all 23 pages of it! Awesome work and a fantastic looking result! Bow down
Post #436863 10th Jul 2015 10:12am
mk1collector
Embarassed thank you Thumbs Up Ray
My build thread
Post #436874 10th Jul 2015 10:57am
AndyTunn
Just a quick photo...
Some of the local scenery - enhanced by my Defender (well, it is to my eyes anyway!)
Post #438505 17th Jul 2015 8:14am
shaggydog
Cracking Shot Thumbs Up
Quite agree with you Whistle Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #438561 17th Jul 2015 12:16pm
AndyTunn
Happy Dog
Just back from a 2-hour dog walk at the local pony club grounds (plus the surrounding woods and scrubland). Couldn't resist a quick photo, even though the Landy is in need of a damn good clean..
Post #440275 25th Jul 2015 5:55am
AndyTunn
Thank you Very Happy
Post #440276 25th Jul 2015 5:56am
mk1collector
What front bumper have you got? Ray
My build thread
Post #440297 25th Jul 2015 9:07am
AndyTunn
Hi Ray, It's just the standard LR bumper, without the end caps, and with Hella Safety Daylights DRL's fitted as per this post...
http://www.defender2.net/forum/post434469.html#434469
Post #440312 25th Jul 2015 11:52am
Page 2 of 5 <12345>
