Home > Maintenance & Modifications > Stainless steel EGR blanking kits
Page 14 of 16 <123 ... 13 141516>
K9F
AndrewS wrote:
So it looks like the 19mm Ø is the one then Whistle
Not for me it isn't! Been on the 10mm one for a couple of months now and not been anywhere near 19mm for about 6 months or so. Admittedly I have had one P1103 code that I cleared with the 10mm but not had a reoccurence of the code since (about 3-4 weeks)! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #43623 26th Oct 2010 10:22pm
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Amos, The EGR valve allows exhaust gasses to be mixed with your engines inlet air. The valve controls how much and when, we would prefer none at all and therefore try to restrict the flow by fitting a blanking plate. Unfortunately we cannot yet blank it entirely as it causes a warning light to show on the dashboard, so we are collectively trying various hole sizes drilled in the plate to allow enough air through to kid the system that all is well. Our finding is that not all Pumas are alike, some get away with a 10mm hole others have to go to almost twice that size before the light stays off. Hope this helps?
Post #43629 27th Oct 2010 5:39am
AndrewS
So the 10mm did throw a fault Thumbs Up Wink 130's have feeling's as well you know Smile
Post #43641 27th Oct 2010 8:51am
Amos
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
But what does it do for my life, does it make the truck go faster, more MPG etc....!
If it is not important, then why doesn't Landrover remove it....!
Post #43642 27th Oct 2010 8:59am
AndrewS
The egr or blanking plate Question 130's have feeling's as well you know Smile
Post #43645 27th Oct 2010 9:00am
Amos
Both....
Post #43646 27th Oct 2010 9:20am
--defender--
United Kingdom 2010 Defender 110 Puma 2.4 HT Zermatt Silver
It's all about emissions and improving stability at low revs. People don't like the method as the EGR re-circulates sooty oily gases into the induction system that can fowl the TMAF sensor and the sooty deposits can eventually clog up the EGR valve itself that then results in sticking. This system only comes into play during light throttle/tick over situations. If it wasn't for the way the ECM monitors it people would junk the whole lot and do without it. Some have demonstrated that restricting flow at the EGR valve has improved economy/performance - I'll sit on the fence until someone finds a patch for the ECM to inhibit the damn thing!
Post #43647 27th Oct 2010 9:23am
Amos
I'll sit on the fence also.....
Post #43651 27th Oct 2010 9:50am
AndrewS
EGR valve EDR = Exhaust Gas Recirculation
+ive for the environment
Its there to allow exhaust gasses back into the engine. The nasty hot gasses get re burnt and in doing so this reduces the noxious emissions coming out of the exhaust.
The valve opens and closes various amounts that’s controlled by the engine management system. Basically at tick over it should be open, on full power it should be closed. When on full power its closed no "spent gasses" get into the combustion chamber, the engine gets nice clean fresh air and provides lots of power Thumbs Up
Earlier engines the EGR valves were controlled via a mechanical device or a very basic engine management system. In this instance the valve could be blanked off stopping the nasty gasses going through the combustion process, this was great as the engine always had nice fresh air to breath and the engine management system had no idea what was going on, however the modern engines have flow sensors in the EGR system so when we blank the EGR on a Puma the sensor throws a warning light on the dash.
This is what this thread is all about, we are trying to reduce the amount of spent exhaust gasses getting into the engine by fitting a blank plate with a hole in it but not restrict the flow too much, thus allowing the sensor to throw a warning light.
Those that have fault code readers that can clear the faults simply clear the faults, those that dont have to take the car to the dealers.
Again this is what this thread is discussing. Whats the smallest hole you can fit without the system throwing a fault.
Take a look at the start of this thread Thumbs Up
http://www.defender2.net/forum/topic3115.html?highlight= 130's have feeling's as well you know Smile
Post #43654 27th Oct 2010 9:56am
Amos
Does this EGR valve affect the new 2011 Pumas.......?
Post #43670 27th Oct 2010 3:04pm
AndrewS
Shocked Are you taking the Censored Shocked 130's have feeling's as well you know Smile
Post #43672 27th Oct 2010 3:46pm
Amos
Not really, if it is a problem....! Then why do Landrover use it..... Thet don't put thing in engines, so the owner can block it up 2 weeks latter....
Post #43676 27th Oct 2010 4:31pm
K9F
Yes it did and as you mentioned some people are able to read and reset! I have the capability of resetting it without taking it to the dealers! Nevertheless the 12, 14, 16mm plates I fitted (think I started at 16? Maybe even 18mm) didn't throw any faults at all!
Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #43681 27th Oct 2010 5:32pm
BIGFOG
Your directness really made me chuckle Wink Thumbs Up Hope Amos wasn't too offended!!! Shocked
Post #43690 27th Oct 2010 6:43pm
AndrewS
Rolling with laughter Thumbs Up Dont do nasty Thumbs Up but do do sarky Whistle Sorry Amos Thumbs Up 130's have feeling's as well you know Smile
Post #43703 27th Oct 2010 7:36pm
