Home > Puma (Tdci) > 2.4 tdci Engine Cutting Out
pumaxs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Zambezi Silver
I'm having some intermittent trouble with my engine Big Cry
The first hint of trouble came when boarding the ferry in Plymouth on Thursday evening, reappeared around Nantes on Friday afternoon, and again whilst visiting family near Limoux last night.
The problem only seems to manifest itself at low speeds.
For example, last night I was driving through a small village, coasting in third gear, with my foot off the accelerator pedal, when the engine just cut out.
There was no coughing or spluttering involved, just the rev counter needle dropping like a stone to zero, and one very dead engine.
You cannot 'catch' & revive the engine by applying throttle.
The engine then restarts immediately, without any hesitation, and I can carry on with my journey, albeit, with the feeling that the low speed throttle response seems slightly rough/jerky.
No warning lights come on when the fault occurs & all go out, as normal, during the start- up procedure.
This occurred three times, in a relatively short distance, last night.
The 110 had it�s 92k service (it�s only done 75k-ish miles) + MOT on the 22nd July � I also spoilt it & had the gearbox oil changed � Without any problems.
I also had the aircon gas levels checked on 1st July � Only 20g added � Again, no problems.
The N/S/R brake light blew on the 3rd July, but has not blown again since having been promptly replaced.
I realise that this is probably going to require seeking out a Land Rover dealership tomorrow, to see what, if any, fault codes are flagged up.
My 2013 trip to Italy required a similar trip, for a faulty light switch that time, so this in danger of becoming a holiday tradition.
Anyway, I thought that I�d kill some time, on a hot + sunny Sunday morning, by seeking advice/opinions here first.
Any ideas? '57 Defender 110 XS Station Wagon 2.4tdci
Post #435878 5th Jul 2015 10:33am
K9F
Your supposition of going to a dealer for diagnosis is correct to see what DTCs are logged. In the interim apart from checking security of relays, throttle sensor etc. there's not much to do. Maybe think of investing in a practical and proven fault code reader perhaps? They can immediately pay for themselves in a situation such as yours.
Good luck! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #435894 5th Jul 2015 11:55am
Check battery terminals are tight, earthing and battery condition.
If nothing else it's good to check it anyway.
Post #435917 5th Jul 2015 2:51pm
pumaxs
Both battery terminals are tight + well greased, so do not think that is the problem.
No other obvious loose connections.
Have spoken to my UK dealership, and they have suggested that problems with the Fuel Metering Valve or Pressure Relief Valve can cause the symptoms that I described, and are fairly common 2.4tdci faults.
However, ultimately I need to get to a dealership to be certain.
So it looks like 1 1/2 hour, or so, drive to Toulouse. '57 Defender 110 XS Station Wagon 2.4tdci
Post #436046 6th Jul 2015 9:21am
pumaxs
Couldn't get into any of the local (and I use the term loosely) dealerships, as they are all fully booked until the end of July!!!
Pleads of "But I'm on holiday!!" cut no ice!!
So, now have a booking for 10.00am tomorrow at Auto Real in Perpignon, some 65 miles & 1 hour 45 minutes away.
A short trip to the Leclerc store up the road confirmed that the problem hasn't gone away, so fingers crossed that I make it without having to lean upon my continental breakdown cover.
Will pack my tent in case I have to wait for replacement parts to be ordered + delivered next day, as can't be arsed to to and fro.
Whilst I'm sure that my impromptu tour of Perpignon will be lovely, sh!t like this really puts a strain on the Defender 'love affair'!!!
I'd already had a call from my mother, the night I'd arrived here, to say that my old ESS, a true gentleman of the first order, had to be put to sleep the day I'd left home.
Boss was an old boy, and had been unwell for a while, but his loss is still a wrench, as you develop such a strong bond with working dogs.
Basically, this holiday is shaping up to being one kick in the b@llocks after another!! '57 Defender 110 XS Station Wagon 2.4tdci
Post #436146 6th Jul 2015 4:59pm
munch90
couldn't spare 10 mins to plug your defender in , that's good back up Rolling Eyes
Post #436148 6th Jul 2015 5:11pm
pumaxs
I suppose when you're busy you're busy!
PITA though! Confused
The guide books say that Perpignon is "one of the hottest towns in France".
Given that it's been 38 degrees here today, that doesn't bear thinking about.
However, the Catalan history sounds interesting, so culture will hopefully win the day! Smile '57 Defender 110 XS Station Wagon 2.4tdci
Post #436163 6th Jul 2015 6:44pm
SimonDavies
Wales 2010 Defender 90 Puma 2.4 HT Zambezi Silver
Do you experience any 'hunting' when the engine is idling over time - I.e. revs bouncing up and down? This can be a symptom of a fuel valve problem on the 2.4.
Post #436182 6th Jul 2015 8:24pm
pumaxs
To be honest, the rev counter needle flutters only very slightly on tick over.
Perhaps, 50 rpm-ish above & below the target 750rpm.
I've seen some YouTube clips where the needle is bouncing about all over the shop.
It certainly doesn't do anything like that. '57 Defender 110 XS Station Wagon 2.4tdci
Post #436184 6th Jul 2015 8:33pm
SimonDavies
I'm guessing you don't have any tools on you? The fuel sensor at the rear of the rail is easy enough to remove with a 19mm (I think). It should all be as one. If it has failed it will be broken up.
If you do have it booked in somewhere and don't want to risk things then obviously wait, just thought I'd throw an idea in.
Post #436186 6th Jul 2015 8:38pm
pumaxs
Well, I made it to the the LR dealership in Perpignan - Just!
The engine must have stalled 7 or 8 times on the closing stages, mainly due to the slow moving traffic + numerous roundabouts.
Anyway, the problem proved to be due to a failed Fuel Rail Pressure Relief Valve (Part No. LR006866), which had broken apart internally.
They also replaced the Fuel Injection Pump Vapour Valve (Part No. LR009837).
An uneventful journey back to Limoux via the beautiful Gorges des Galamus, with it's narrow + winding road, confirmed that all is well again. Very Happy Thumbs Up '57 Defender 110 XS Station Wagon 2.4tdci
Post #436454 8th Jul 2015 7:11am
Caterham
Thumbs Up
great news and what a relief I should imagine.
Post #436463 8th Jul 2015 9:06am
pumaxs
Relief cost me just over �500.
But sure felt good! Laughing '57 Defender 110 XS Station Wagon 2.4tdci
Post #436475 8th Jul 2015 9:53am
SimonDavies
Thumbs Up Very common on the 2.4.
Glad you have sorted it but by gosh that's pricey.
Post #436513 8th Jul 2015 1:01pm
pumaxs
Roughly translated, the bill breaks down as:
Diagnostic Testing: �75.00
Labour: �126.40
FRPR Valve: �39.98
FIPV Valve: �173.76
Cleaner: �5.00
VAT: �84.03
Total: �504.17
Not ideal, but neither is breaking down in the middle of nowhere in a foreign land. '57 Defender 110 XS Station Wagon 2.4tdci
Post #436531 8th Jul 2015 3:09pm
