Home > Maintenance & Modifications > Roof Insulation, Head Lining Removal and Re-Trimming
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Hi All
I've trawled the search results but can't seem to find a definitive answer on a couple of points:
Is the removal of the roof lining on a Puma 90 relatively simple. From looking at the car it looks like:
1. Remove visors
2. Remove light
3. Remove winscreen corner pillars
4. Remove all rear window/side panels
5. Fight the fir trees
Secondly, does anyone have any advise on what thickness of closed cell foam (or other insulation) you can get onto the roof without fouling the headlining on refit?
Oooh and one last question; Has anyone had their headlining re-trimmed (black, of course Smile)? Any recomendations? I see you can buy replacements but they are hideously expensive.
TTFN
Barney
Post #436079 6th Jul 2015 11:35am
jimbob7
I bonded 1.5mm rubber sheet to the roof then fitted a rad haz kit,which i think is 10mm (+foil+cover),it's a tight squeeze under the headlining,but I made no effort to trim the rad haz kit,the visors and mirror (if you fit the mirror,) also help keep the roof lining up.You'll probably (will) need new fir trees (can get black ones from Halfords).I only did the front tho as mine is a H/T.Quieter and warmer/cooler,a very cheap mod. Pov.spec,ftw. 2006, 110,TD5.
Post #436115 6th Jul 2015 1:58pm
consumerize
United Kingdom 2004 Defender 90 2.5 TD SW Java Black
I used SilentCoat vibration control, then about 8mm foam stuck on top of that. didn't interfere with replacing headlining.
Made a big difference to noise reduction and temperature in the cabin.
I re-covered my headlining in Alcantra using heat resistant spray on glue, designed for car upholstery. It looked very smart. With the recent heat, the heat resistant glue is failing to do what it said on the tin, and is sagging in places. It now starting to feel like I'm driving around in a tent.
Post #436123 6th Jul 2015 2:20pm
Tiger
It's a Censored of a job but you need to cut/peel off the original beige trim and then glue the Alcantara to that then the glue won't fail.
Post #436125 6th Jul 2015 2:24pm
consumerize
Now you tell me !
Post #436132 6th Jul 2015 2:38pm
Tiger
Guess how I know.....
Post #436134 6th Jul 2015 2:39pm
Caterham
Not sure what hideously expensive is but it might be worth dropping IRB a line as I seem to recall they can do this at a very reasonable price.....
Might be a better option in the long run?
Post #436158 6th Jul 2015 5:28pm
Barney12
Thanks. Is that these guys?
http://www.irbdevelopments.com/home.html
Post #436172 6th Jul 2015 6:30pm
Caterham
Yes. Thumbs Up
Post #436180 6th Jul 2015 7:07pm
Barney12
Thanks. Email sent.
Post #436211 6th Jul 2015 9:48pm
Barney12
Just to update:
I've found a local trimming company that will retrim in black for a couple of hundred quid as long as I remove and refit.
Interestingly he said its that expensive because of the need to completely strip the existing trim and foam so that you get a permanent fix of the new lining. He also mentioned that its key not to stretch the fabric too much as otherwise it will fight to return to its unstretched form over time.
Post #436602 8th Jul 2015 8:23pm
Bristol 90XS
Hi Barney - where did you find to do this locally? Am quite interested in this too!
Thanks
James
Post #436724 9th Jul 2015 3:49pm
Barney12
This guy here:
http://www.westcountrytrimmers.co.uk
I was very impressed by what I saw.
Post #436847 10th Jul 2015 8:54am
Caterham
hi guys,
can anyone confirm if these are the right jobbies for the roof trim.....they don't look very long.
http://www.halfords.com/workshop-tools/gar...el-buttons
many thanks,
Post #558804 25th Aug 2016 8:44am
Barney12
Post #558816 25th Aug 2016 9:47am
