Home > Puma (Tdci) > Airconditon fuse / Wiring diagram
Td5
Finland 1996 Defender 90 300 Tdi CSW Coniston Green
Hello,
I just recently bought a 2007 90 Defender Puma and the A/C don't work.
Did some preliminary checking and the A/C fuse was blown, replaced it and
it blew immediately when A/C switched on.
Disconnected the condenser fan and the fuse don't blow.
Hooked power to the fan and it run OK. Switching on the A/C when
condenser fan disconnected, the fuse don't blow, but compressor don't
start. There is "enough" refrigerant in the system, checked pressure.
I have the factory service manual in PDF, but from where could I get the
wiring diagrams? There is suspicious jumper wires in the fuse box, so
probably I have some electrical work to do.
Sorry about my English, I'm not native English.
TIA,
Juha
Post #435447 3rd Jul 2015 4:45am
K9F
RHD but wires will be the same... Thumbs Up
Diagrams....follow link. Good luck! Thumbs Up
https://onedrive.live.com/view.aspx?cid=4B...&wdo=1 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #435480 3rd Jul 2015 8:30am
Td5
Thanks, K9F.
Got the wiring diagrams, but wondering where the relays are? There is a separate relay for the A/C clutch
and one for the condenser fan. They probably are under the seats, but someone installed Recaro seats
that do not have the cushion removable, I have to take some photos to show what I got.
These I have somehow convert so that the whole seat can be removed easily if/when needed.
Could someone tell the location of these relays, please.
Post #435585 3rd Jul 2015 4:27pm
K9F
Either under the passenger seat or under the steering wheel on right hand drive vehicles. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #435587 3rd Jul 2015 4:42pm
