Home > Puma (Tdci) > 2015 air con- pants or broke? |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Aircon is actually quite good in the Puma's, sounds like It's faulty.
Mine didn't work when new either, ended up with a new compresser Guns and Landrovers .... anything else is irrelevant. |
29th Jun 2015 7:23pm |
If you can get a thermometer and poke end in the air duct , air temp coming out should be 8-10oc with air con on , maybe slightly higher if sitting still on tickover , about 8-10 driving
on tickover sitting still can you hear the pump cutting in and out ? Electric rad fan cutting in and out ? Last edited by munch90 on 29th Jun 2015 8:15pm. Edited 1 time in total |
29th Jun 2015 7:26pm |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 617 |
I found it can blast icy air at my left knee and forearm while the rest of the cabin, particularly the back row passengers are still uncomfortably warm. The downside of a USW, but the air coming out of the vents is actually cold.
29th Jun 2015 7:34pm |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 248 |
I thought mine was not that good, until i inserted my special temperature probe into the vent.. it went down to 4 degrees c. just takes a while to cool the passenger compartment down. 1953 80"
1987 mini city e 2011 90" |
29th Jun 2015 8:31pm |
Be honest doudt you would get 4 oc in hot weather
air con performance does depend on outside temp , of course its easier to get rid of heat to colder outside air |
29th Jun 2015 8:38pm |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1217 |
use mine all the time..
pretty good I reckon. never measured it but gives a nice cold blast Clemmo Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
29th Jun 2015 8:45pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
put it on recirculate to cool the whole cabin quicker 2002 90 Td5 Station Wagon
29th Jun 2015 9:04pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2526 |
HI Jimbo, Got a 2015 XS, three weeks old, only used the aircon once but it was very efficient. Sounds like a warranty claim. Just because its a Defender and not a Disco doesn't mean we have to accept inferior equipment, after all you shelled out 30,000 of the Queen's pounds for it.
29th Jun 2015 9:15pm |
the temp of the air from car air con will be much the same on all cars whatever make as they all use the same gas (r134a) , its a low pressure fridge gas , the pressure it works at and type of gas which determines the temp it will drop to. example :household freezer will use a higher pressure gas ( think its something like r401 ) which will give a lower temp for freezing
of course the amount of air blown between different cars/makes etc will have a effect on how quickly it cools a space down and how cold the air pipes/ducts are it travels through to get to cabin makes a difference older cars use r404 which as far as I know gives lower temp , but makes bigger holes in the ozone layer . illegal to use now newer cars use r134ar , not sure about this one and not sure if new defenders use it there should be a sticker under bonnet that tells you amount and type of gas fitted under or overfilled air con system will give a higher temp , but there is only one way to tell and that is remove and weight it , no good checking pressure of gas as 10g of gas will give same pressure as 500g you need to check working pressures on high / low side of pump with it working to tell if it working as it should low side = 25-40ish psi high side = 150-180ish psi ( pressures will depend on outside temp/airflow ) DO NOT TRY THIS AT HOME thing that does make a difference is air flow through front rad (condenser ) , so if electric front fan not working will have effect Last edited by munch90 on 30th Jun 2015 6:20am. Edited 2 times in total |
30th Jun 2015 6:03am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
If you don't use air con all the time it will dissipate over time as the oil rings that seal the system dry out shrink and the aircon fairy dust escapes
Me I just leave it on |
30th Jun 2015 6:17am |
its reckoned any air con system will LOSE 10% of gas per year ( that's a good system with no traceable leaks ) of course if it leaks it will lose it quicker and illegal to refill
you don't really need to use it all the time , once a month/week will throw a bit of oil round the system not sure about the o rings shrinking as new ones that have never had oil on them in a box don't shrink corrosion creeping in the joints and under o rings does and of course holes in pipes etc , front condensers and rubbed through pipes are most common leaks |
30th Jun 2015 6:23am |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3784 |
jimbob, Hello from sunny downtown Aus, where it does get HOT.
If that is your experience with your Puma A/C, then there is definitely an issue with it. It's certainly not the best A/C system, & on a warm day in a 110, I'm not sure how much cooler the rear passengers would be?! But we have a 90, and we've had it out in 36/40C, & whilst it ain't perfect, it "does the job", for the two of us in a 90 anyway......wouldn't wanna be without it that's for sure.. So, take it to your Dealer & have him check it out. Pickles. |
30th Jun 2015 6:47am |
Cafe Latte Member Since: 27 May 2015 Location: Ravenshoe Posts: 10 |
I am in Aus too in Queensland and it get seriously hot here. My 2015 Puma aircon is so cold I need to divert the vents away from me. If you are warm in the UK your aircon is faulty (I grew up in the UK even a heatwave in the UKis not hot for Aus).
Chris |
30th Jun 2015 9:20am |
Jimbob Member Since: 17 Mar 2011 Location: Gower Posts: 68 |
Thanks for all the replies guys only now seeing this, there's definitely something wrong I'll be booking it in next week, we're having the hottest weather ever at the moment and I tried all combinations and all I got was warm air so something must be up, did a motorway jaunt yesterday and was so hot I gave up and opened both windows just to get it to cool which wasn't exactly the comfiest at 70mph but needs must! I had to shut them for 10 mins then to hear the sat nav and I tried it again and I was soaking within 2 mins lol (too much info probably lol)
So yeah bottom line is it's going back! Once again thanks for the replies! 2009 Defender County Hard Top (gone 😞) 1990 200tdi defender off roader 2015 Defender XS Hard Top (awaiting delivery 😄) |
1st Jul 2015 8:26am |
