![]() | Home > Technical > Engine or PTO driven compressor to run air tools? |
What sort of air tools ?
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 301 ![]() ![]() ![]() |
Drills, Die grinders, impact drivers in short bursts.
impact you don't need much air for as normally only used in short bursts , die grinder/drill you will need more air
to be honest I think you will struggle to find a pto compressor or engine compressor small enough with a descent output |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
To run an air drill you will need a compressor with at least 90 psi at 5.0 cfm out put. Just to keep your drill running.
Myself I would go electric. The chances of finding a pto / belt driven compressor to fit would be expensive. You may be able to find an air con compressor to do the job, but it must have it`s own oil supply for the compressor. All the best. Excuse the spelling I`am better with spanners and wires. |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
They're out their, needs a bit of research my quick search found this http://www.endlessair.com.au/
I'm beginning to want one now haha most of the land rover engines have a nice indent for add ons like this, even the air con puma has a cap below the alternator |
We run air drills, wrenches etc off our tractor air compressors (for the brakes) so something non silly big should be doable and work.
I was thinking about using a belt driven Air Con pump feeding a chassis mounted tank, pity there is no ready made kits around.
Zeissman Member Since: 28 May 2015 Location: Scotland Posts: 44 ![]() ![]() ![]() |
Hi try and google this VMAC Underhood Air Compressors: Finally, a Truly Portable Air Compressor, they are not cheap but you can run ANY air tools including a jack hammer we use them on ford 150 over seas and run drills grinders the full nine yards I don't think you understand, these boys killed my dog
I'm just a pecker wood who lives in the hills with too many guns and a land rover defender |
ChrisWoods Member Since: 29 Dec 2016 Location: Spreyton Posts: 164 ![]() ![]() ![]() |
Old thread but didn't want to start a new one. A PTO driven air compressor would be the best solution for on board air. I don't think anyone makes one but I wish they did. Pretty simple for someone with the right tools to manufacture one or even just manufacture an adaptor. Could retail it for £500+ and im sure people would buy it. Not a lot of room under the bonnet for a belt driven one and 12v ones just aren't as heavy duty. 2009 2.4TDCi XS Utility Wagon.
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 624 ![]() ![]() ![]() |
Do a search on google for "on board air", a mate of mine got some bits from them and ran his set up with a range rover air-con pump on his disco 1 with pretty good results ![]() Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
roliver Member Since: 24 Nov 2016 Location: Cambridge Posts: 60 ![]() ![]() ![]() |
I've been thinking about this lately. I have a TDCi and I was wondering if the air conditioning compressor could be used? I think the TDCi engines take one of the Sanden SD7H15 compressors. According to the manufacturers website, this produces 154cc/rev. Not sure if that is sufficient grunt to power tools or not??
Very easy job if you don't already have air con installed. If attached to the PTO, I guess you could use transferbox oil to lubricate it. 2009 2.4TDCi XS Utility Wagon.
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
I suppose my question would be how much would it cost to run?
A portable petrol driven compressor with a 125cc engine might be cheaper to run than a 2.2/2.4 Diesel engine. |
I kinda meant as a bulletproof compressor for occasional use, not something you run for hours with a nail gun on the end. 2009 2.4TDCi XS Utility Wagon.
