Home > Maintenance & Modifications > X member fixings / brackets
Why is I notice some Defenders x member bracket fixings on top of the panel at the rear and underneath on others.
From factory on mine a Puma it is underneath so all you see is the bolt heads not the x memeber brackets.
Is this due to different year variations or in-correctly fitted Question
Post #433644 25th Jun 2015 7:06pm
GUM97
Age variations. Up to Td5 had brackets over the tub, TDCi Puma have brackets underneath the tub, hence only the bolt heads visible Thumbs Up An engine to TDi for!
Post #433653 25th Jun 2015 7:33pm
Ah that makes sense, cheers.
I've wondered this one for a while so now I know
Post #433709 25th Jun 2015 10:54pm
Martin
Site Admin
Td5 have the sliding rear body mount too. Tabs over the tub ended with the last Tdi Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #433737 26th Jun 2015 7:22am
