![]() | Home > Maintenance & Modifications > Nas style rear step for Defender 90 help. |
Mrpheasant Member Since: 03 Feb 2015 Location: Cheshire Posts: 22 ![]() ![]() ![]() |
Just wondering if anyone who has got a rear step like this one could help me...
Click image to enlarge the kit only came with 1 what i would call a support beam, that goes from the step to the defender... ![]() Click image to enlarge my question is should there be 2? one either side of the step, i took 2 off the towing kit which was on before so in my mind it makes sense for there to be 2 on this step. any help would be great... |
Yes should come with 2 bars
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1847 ![]() ![]() ![]() |
should be 2!
And give the step a good waxoyling in the corners and underneath
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20694 ![]() ![]() |
Already mentioned twice but indeed needs to be two.
Awesome, thanks guys
Hammerite stuff any good? |
You can't get it inside too well without drilling holes, would small holes big enough for an internal spray tube compromise structural strength?
Have a look on Topix for the fitting instructions (assuming it's an OEM kit) - looks like you're a bolt or two short as well.
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 ![]() ![]() ![]() |
I'd also suggest moving the electrics, so there is no chance of them being pulled off by a stray branch...
Yep it shows it as having two ![]() |
I like the idea of that ![]() |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello Mrpheasant
As has been said Yes...there should be two 'arms' in the kit... ![]() and ... ![]() ![]() Click image to enlarge Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
Dumb question maybe but how did you go about mounting it there Skip?
