Home > Wheels & Tyres > 2010 Defender tyre/rim question
Page 2 of 3 <123>
--defender--
United Kingdom 2010 Defender 110 Puma 2.4 HT Zermatt Silver
Michaels Defender wrote:
I run 265 KL71 on my 110, using the SVX wheels, I had to adjust the steering stops which has reduced the turning circle, and when the spare is fitted it traps the rear wiper
Thanks for that Michael, I wonder if others have problems mounting their spare wheels too. Turning circle is pretty poor as it is, I'd hate to lose anymore Sad
Pictures of your Defender looks great, thanks for sharing them with me.
Post #43214 21st Oct 2010 3:42pm
Michaels Defender
United Kingdom 2013 Defender 110 V8 Petrol XS CSW Auto Orkney Grey
I could have gone for spacers, which would give me more lock and I have even thought of putting some kind of spacer on the spare, so can use my rear wiper Exclamation, but I did not want to go down the spacer route and upset my insurance company JE Zulu 110 now sold
Carpathian 110 also sold
Defender 110 camper now in build
Post #43215 21st Oct 2010 3:53pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
I can't remember by how much but my wheels are offset and i did not have to adjust the stops.
Post #43227 21st Oct 2010 6:33pm
--defender-- wrote:
Just as well the door is made of steel!!
I wouldn't hang one off even a steel door - I have a Sonic spare wheel carrier (top product Thumbs Up ). Mind you on a DC I don't have a door anyway.
There is no reason why good quality spacers should be any more of a problem from the insurance or handling point of view than wheels with a different offset.
285's on standard rims with a 30mm spacer just keeps the tyre under the arch. Turning circle (and lockstops) are exactly the same as on the original 'space-saver' tyres.
Result looks like this (but note this was before the spacers were fitted)
Post #43264 21st Oct 2010 9:45pm
bjf
United States
Why did you need spacers. A bit confused. 265/75/16 isnt a big tire. You shouldn't need to adjust anything to use them. The spare rubbing the wiper also is confusing me. Any pics?
Post #43522 26th Oct 2010 4:36am
K9F
If you do the sums and if necessary alter the wheel size accordingly to 'maintain your original rolling radius' (if you want bigger tyres) don't bother spending the extra cash (£350 in my case) just to purchase a spare? Buy a decent cover and keep the original as a get you home one!
Mine are 40mm offset, no spacers and no adjustments either!
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #43524 26th Oct 2010 7:09am
BigMike
For the spare just use a nut on each bolt. I'm running maxxis bighorns and my spare fouls the wiper too, but the nuts will sort it out, its only a couple of mils. In fact this has reminded me to sort this out now winter's coming.
Post #43530 26th Oct 2010 7:59am
--defender--
Thanks for all your advice. Most useful..
Post #43534 26th Oct 2010 8:59am
MK
I have 285´s on 8" rims and 0 offset. It is the right setup for larger wheels in my rig. Puma 110" SW
Post #43537 26th Oct 2010 9:14am
--defender--
K9F, those look like ZU rims? That makes perfect sense to me. Fifth tyre, possible spacers and a rear tyre carrier all add up...
Post #43540 26th Oct 2010 9:32am
K9F
Wish list = Lots o' dosh!
They're Mach 5s deeper than Zus if you compare, dropped down to 15" from standard 16" so I could fit bigger boots on! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #43541 26th Oct 2010 9:35am
--defender--
Assuming those Mach 5's are steel 8" rims? What size coopers do you have fitted on those?
Post #43542 26th Oct 2010 9:57am
K9F
8"??? No!! they're not ice cream van wheels you know!!! Laughing
Those are Carlos Fandango 10" here's a picture next to my size 10 trainers.
Tyre size High Flotation 32 x 11.5 x 10 Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #43546 26th Oct 2010 10:40am
--defender--
You're only size 10, with boots as large as those on your landy! Laughing
I guess you have beefed up your CV's, Half-shafts & diff with tyres as large as those?
Clever choosing tyres having the same circumference as the original 7.5R16's, I like the idea of not buying a spare and using the original wheel/tyre as a "get me home". Additionally: If towing the coupling height isn't effected by fitting larger diameter tyres.
Thanks for the info... They're huge and look very expensive - very nice.
Post #43551 26th Oct 2010 11:06am
K9F
Nothing has been beefed up at all....I am not an avid off-roader and with all the abuse a Defender is designed to take, and indeed does from some of the photos on here and from historical off-roading experience decided for my usage 'standard' was sufficient. The tyres were not extortionate in my view at £130 a pop! I am heavy-footed with my driving and will rectify if and when needed but after 18 months of fitment everything still seems fine and dandy! I have also been very lucky with my Puma having not sufferred or experienced many of the gearbox and clutch issues that many others have had to endure thankfully! No complaints really!
Post #43566 26th Oct 2010 3:23pm
Page 2 of 3 <123>
