Home > Maintenance & Modifications > 230V inverter installation |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6312 |
can anyone recommend an inverter and installation
I'm looking to install one - nothing too big c300W probably in the rear? anyone done this already - any pros / cons? |
21st Oct 2010 7:49pm |
--defender-- Member Since: 22 Apr 2010 Location: South Coast Posts: 90 |
Any inverter will sap the vehicle battery before you know it, I'd install a 2nd auxillary battery fed from a split charge relay. This will ensure you've plenty of juice to start your engine.
21st Oct 2010 8:07pm |
surely a 300W jobbie would be ok for an hour or so ?
21st Oct 2010 8:15pm |
oops - i thought the batteries were rated about 200A / hours (obviously not?)
21st Oct 2010 8:38pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
I have a 1500w inverter in J-Lo its mounted over the rear wheel arch. Its connected to 3 battery's that are placed under the 2nd row seats. 130's have feeling's as well you know
21st Oct 2010 8:45pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Where do you get yours! I think mine's about 90A/H and it wouldn't do much with only a third charge left in it. |
21st Oct 2010 8:47pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
A 300 watt inverter would draw about 28amps at full power, so at full power you have 2 to 3 hours on a standard battery. We use our inverter whilst driving so we don't run into the flat battery syndrome.
The inverter runs off the second battery hence protecting the main starter battery. The split charging system also has an audible low battery alarm. HTH Brendan |
21st Oct 2010 8:49pm |
thanks guys
so an inverter for on the move or a split battery jobbie. |
21st Oct 2010 8:52pm |
Twin batteries or inverters?
Really depends on what you need from your vehicle? If you intend running a fridge/auxilary lights etc then twin batteries are good. If you want to just charge your laptop up whilst on the move then an inverter is fine. If you are planning on equipping vehicle for overland trips then you might want both a twin battery system and an inverter. What are you planning to plug into the inverter? Could you get away with a 12 volt adapter for whatever equipment you are going to plug into the inverter? Brendan |
21st Oct 2010 9:51pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
I will install a 1500W inverter + 2 deep cycle batteries in our folding camper and an isolator to prevent to drain the car battery when are hooked-up. As we will probably spend a lot of time camping without electricity for this reason this setup.
A nice formula to see how much time is needed to drain a 12V 100Ah battery is as follow: Time in minutes = 11609 x (current in Amp) ^-1.3269 So, if you have, let said a 300W consumption means 300/12 = 25Amp T = 11609 x 25^-1.3269 = 162 minutes A 800W hairdresser can last your battery in just 44 minutes, and so on. Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
22nd Oct 2010 1:27am |
