Home > Puma (Tdci) > Low box whine and A/C fan cycle
grafty99
Today is the first time I've got out of 2nd gear low range, anything above about 5 mph and the transfer box screams like a banshee! Both my old td5 and my dads 300tdi make a slight noise but my new one is deafening! Are the low gear ratios straight cut?
Also I've noticed that when the aircon is on, the electric fan spools up to speed, stays on for a second then cuts out, it repeats this 3 times in succession then there is a 20 ish second pause before the cycle begins again, is this normal?
Cheers, George Very Happy 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #432289 19th Jun 2015 11:16pm
munch90
A/c acting right , fans stops and starts as pressure rises and fall when pump cuts in and out
hard to say about low range , gears can be noisy until run in to each other and guessing you dont use low much it could take long time to quieten down , try and have a listen to another one at dealers or friends one
Post #432292 20th Jun 2015 4:36am
Matt110
Wouldn't worry about the fans cycling, mine does that too. Same vehicle as you.
The transfer box doesn't sound right though. Mine now has a few thousand on it, built in the same MY as yours, and low range doesn't have any whine at all. Difficult to tell without seeing the vehicle though.
Got any way to upload a video with some sound?
Post #432302 20th Jun 2015 7:14am
grafty99
Yeah I could try to do a video. May get one done tomorrow, it is definitely much louder in low range than our other 2 defenders. Am I right in assuming that the only difference between the t-box between the tdi/5 and the puma is that the puma has a quieter running gear set in high range? (Ignoring the high range ratio difference?) 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #432322 20th Jun 2015 8:55am
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
It is probably normal.
I have always thought Pumas sound dreadful in low range. Quietening down has been mentioned, my td5 Defender, my old V8 (with a brand new - not recon), and various disco 1s & 2s have been nowhere near as noisy!!
Post #432357 20th Jun 2015 11:29am
