Home > Puma (Tdci) > Low box whine and A/C fan cycle |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Today is the first time I've got out of 2nd gear low range, anything above about 5 mph and the transfer box screams like a banshee! Both my old td5 and my dads 300tdi make a slight noise but my new one is deafening! Are the low gear ratios straight cut?
Also I've noticed that when the aircon is on, the electric fan spools up to speed, stays on for a second then cuts out, it repeats this 3 times in succession then there is a 20 ish second pause before the cycle begins again, is this normal? Cheers, George 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
19th Jun 2015 11:16pm |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 680 |
Wouldn't worry about the fans cycling, mine does that too. Same vehicle as you.
The transfer box doesn't sound right though. Mine now has a few thousand on it, built in the same MY as yours, and low range doesn't have any whine at all. Difficult to tell without seeing the vehicle though. Got any way to upload a video with some sound? |
20th Jun 2015 7:14am |
Yeah I could try to do a video. May get one done tomorrow, it is definitely much louder in low range than our other 2 defenders. Am I right in assuming that the only difference between the t-box between the tdi/5 and the puma is that the puma has a quieter running gear set in high range? (Ignoring the high range ratio difference?) 2002 90 Td5 Station Wagon
20th Jun 2015 8:55am |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 283 |
It is probably normal.
I have always thought Pumas sound dreadful in low range. Quietening down has been mentioned, my td5 Defender, my old V8 (with a brand new - not recon), and various disco 1s & 2s have been nowhere near as noisy!! |
20th Jun 2015 11:29am |
