Home > Wheels & Tyres > 2010 Defender tyre/rim question
Page 1 of 3 123>
--defender--
United Kingdom 2010 Defender 110 Puma 2.4 HT Zermatt Silver
Hi,
Sorry about asking questions that have already been answered but I can't seem to get the "search" function to work..
I'm looking at fitting Kumho KL71 MT 265x75x16's on my 110 using some modular rims, what width rims should I select, 7" or 8" x 16 rims?
Cheers.
Post #42413 11th Oct 2010 1:18pm
RED-DOT
8" of course but i have had a set of 265 KL71's on for a year now and changed back to my 265' BFG M/T's and the BFG is the quieter and better tyre. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #42414 11th Oct 2010 1:23pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Either 7 & 8 will do for 265's, both safe to use.
Post #42416 11th Oct 2010 1:48pm
265 will sit better on a 7J but if you think intime you may gofor 285's then without question 8J
Post #42417 11th Oct 2010 2:11pm
--defender--
Thanks for all your posts, very helpful.
Post #42563 12th Oct 2010 10:38pm
--defender--
What's the advantages on 285's over 265's? Will they fit under the arches without mods or spacers? I'd assume fuel economy would suffer Sad
Post #43194 21st Oct 2010 10:30am
285's fine on modulars with no Mods
As for MPG I dont look ? sorry
Post #43198 21st Oct 2010 12:05pm
--defender--
Any photos and what's the advantages of 285's over 265's?
Cheers!
Post #43202 21st Oct 2010 1:03pm
TACK
Check my gallery, 285 on 8" steel modulars no spacers required, no suspension lift either...
Post #43205 21st Oct 2010 1:34pm
The Boy
8.5" wheels, no lift. Only advantage I can think of is ground clearance from diff to ground.
Post #43206 21st Oct 2010 1:41pm
--defender--
Cheers!
Thanks Tack & The Boy.
Tack - those BFG's look great on the black mods.
Thanks for sharing the photos.
Post #43207 21st Oct 2010 3:09pm
Cheers!
I run 285 KL71s on standard Boost alloys with 30mm spacers and they are fine. Probably no real advantage but they look good! Mind you the spare becomes very big and heavy.
Post #43210 21st Oct 2010 3:19pm
--defender--
blackwolf wrote:
Cheers!
Just as well the door is made of steel!! I like the look of the KL71's, seen some 265x75x16 on black modulars, having mixed feedback on these. Guys local to me love them, some prefer the BFG's tho. I've had BFG's before on a RR and they lasted very well and looked good too. I'll see what sort'a deal I can get for a set of 5 Whistle
Post #43211 21st Oct 2010 3:31pm
Michaels Defender
United Kingdom 2013 Defender 110 V8 Petrol XS CSW Auto Orkney Grey
I run 265 KL71 on my 110, using the SVX wheels, I had to adjust the steering stops which has reduced the turning circle, and when the spare is fitted it traps the rear wiper
 JE Zulu 110 now sold
Carpathian 110 also sold
Defender 110 camper now in build
Post #43212 21st Oct 2010 3:33pm
The Boy
Before I bought the mantec carrier my spare was hung on the door in the normal manner. It pulled the top of the door out about 10mm and rubbed the paint off the bottom near side where it caught on the lower frame. If you are getting a set I personally would recommend getting some sort of carrier.
Post #43213 21st Oct 2010 3:35pm
Page 1 of 3 123>
