![]() | Home > Technical > fuel cut off valve |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Has anybody fitted one of these below to a Puma.....is the flow good enough and has anybody had any problems?
if you dont want to post on a open forum can you pm me as it would be most appreciated as i was thinking of fitting one with a 12v remote switch! http://www.ebay.co.uk/itm/DURITE-ANTI-THEF...&rt=nc |
where is the fuel pump Situated?
personally I would want bigger bore than 3.5mm as the diesel circulates quite fast on common rail diesel
if the pipes are 8mm ish then I would say you need a valve of 8mm ish any restriction might cause pump to draw air in and cause starting/running problems |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 ![]() ![]() ![]() |
Have seen the full kit on ebay and was thinking about it too http://m.ebay.co.uk/itm/Fuel-Cutoff-soleno...0664257369
On a 2.4 it's on the engine. On a 2.2 there's a lift pump too. |
ive got a 2.2 puma ....so could you fit it after the lift pump? i have just seen some bumph that you fit it between the filter and the lift pump!
Thanks munch I was hoping someone on here would comment if they have fitted one or if not willing to discuss openly they could have pm me! it also states that "Not suitable for vehicles with re-circulating (or leak off) system" does anyone know if this applies to a puma defender! |
Not many diesels ( if any ) dont re circulate the diesel nowdays , guessing reason is because of bore size of the valve
the 2.2 with electric pump inside the fuel tank has the cut off valve
the 2.4 without electric fuel pump DOESN'T NEED the fuel cut off valve because if the engine isn't running there isn't fuel demand and when the engine is running YOU NEED the fuel (and suction line has a slight negative pressure). Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
degardel i may be muisunderstanding your poat but ...this post is about adding an extra cut of valve with a hidden switch to use as an anti theft device!
![]() ![]() ![]() I had too much haste in responding ![]() ![]() ![]() ![]() IID Pro MV License |
Buuuut
on 2.2 why don't use THE inertia switch like anti theft adding a electric switch on connector/lines C0123??? ![]() Click image to enlarge ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 624 ![]() ![]() ![]() |
There is a larger version of that valve from Durite:
http://www.durite.co.uk/itm/Anti-Theft-Sol...lve/012962 But still only suitable for up to 3 bar, not sure if that is enough for a modern diesel. |
3 bar it's enough Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
