Home > Technical > fuel cut off valve
nitram17
fuel cut off valve
Has anybody fitted one of these below to a Puma.....is the flow good enough and has anybody had any problems?
if you dont want to post on a open forum can you pm me as it would be most appreciated as i was thinking of fitting one with a 12v remote switch!
http://www.ebay.co.uk/itm/DURITE-ANTI-THEF...&rt=nc
Post #431518 16th Jun 2015 10:45pm
Lorryman100
Simon at X eng did a good quality fuel cut off valve for the defender unfortunately the fuel lines on the Puma are very easily kinked, damaged and you will need to bleed the entire fuel system after it is fitted. Also as there is no lift pump on the Puma if there is a leak in the vacuum feed to the fuel pump you won't be going anywhere. JMTW Thumbs Up
Post #431522 16th Jun 2015 10:54pm
nitram17
where is the fuel pump Situated?
Post #431531 17th Jun 2015 1:35am
munch90
personally I would want bigger bore than 3.5mm as the diesel circulates quite fast on common rail diesel
if the pipes are 8mm ish then I would say you need a valve of 8mm ish
any restriction might cause pump to draw air in and cause starting/running problems
Post #431538 17th Jun 2015 5:40am
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Have seen the full kit on ebay and was thinking about it too http://m.ebay.co.uk/itm/Fuel-Cutoff-soleno...0664257369
Post #431589 17th Jun 2015 10:14am
Cupboard
On a 2.4 it's on the engine.
On a 2.2 there's a lift pump too.
Post #431657 17th Jun 2015 3:39pm
nitram17
ive got a 2.2 puma ....so could you fit it after the lift pump? i have just seen some bumph that you fit it between the filter and the lift pump!
Post #431684 17th Jun 2015 5:17pm
nitram17
Thanks munch I was hoping someone on here would comment if they have fitted one or if not willing to discuss openly they could have pm me! it also states that "Not suitable for vehicles with re-circulating (or leak off) system" does anyone know if this applies to a puma defender!
Post #431687 17th Jun 2015 5:20pm
munch90
Not many diesels ( if any ) dont re circulate the diesel nowdays , guessing reason is because of bore size of the valve
Post #431721 17th Jun 2015 6:45pm
dgardel
Italy
the 2.2 with electric pump inside the fuel tank has the cut off valve
the 2.4 without electric fuel pump DOESN'T NEED the fuel cut off valve because if the engine isn't running there isn't fuel demand and when the engine is running YOU NEED the fuel (and suction line has a slight negative pressure). Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #431749 17th Jun 2015 8:11pm
nitram17
degardel i may be muisunderstanding your poat but ...this post is about adding an extra cut of valve with a hidden switch to use as an anti theft device!
Post #431751 17th Jun 2015 8:16pm
dgardel
Italy
Embarassed Embarassed Embarassed
I had too much haste in responding
Embarassed Embarassed Embarassed Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #431753 17th Jun 2015 8:18pm
dgardel
Italy
Buuuut
on 2.2 why don't use THE inertia switch like anti theft adding a electric switch on connector/lines C0123???
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #431764 17th Jun 2015 8:35pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
There is a larger version of that valve from Durite:
http://www.durite.co.uk/itm/Anti-Theft-Sol...lve/012962
But still only suitable for up to 3 bar, not sure if that is enough for a modern diesel.
Post #431798 17th Jun 2015 10:01pm
dgardel
Italy
3 bar it's enough Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #431807 17th Jun 2015 10:28pm
