Home > Technical > fitting alloy wheel on spare wheel carrier.
Culminator
OK, I'm almost too embarrassed to ask but since I re purchased my 98 tdi, the previous owner confessed that he'd lost the spare wheel nuts when he was having some work done on the rear door. I've just picked up some nuts, 3 like normal wheel nuts and 3 smaller open ended steel nuts that act as spacers I'm told.
however, when I mount the wheel on the carrier and use just the normal wheel nuts, theres too much thread to clamp the wheel. The smaller nuts have a tapered end but they seem too small a diameter to use on the wheel without damaging the alloy as it tightens down. what am i doing wrong or have i got something missing?
https://www.defender2.net/gallery/albums/u...010919.JPG
Post #431350 16th Jun 2015 2:30pm
SailingTom
wind the 3 mounting disks out untill the wheel is secured by the alloy wheel nuts on the outside. They should just undo and wind outwards so the wheel sits further out.
You might have to do it a couple of times to get it perfect.
Hope this helps
Post #431352 16th Jun 2015 2:41pm
munch90
put the steel wheel nuts on inside (taper in towards door ) then washers then wheel , use alloy wheel nuts to hold wheel on
adjust how you need it by adjusted steel wheel nuts on inside to make sure wheel doesn't hit door/wiper arm etc , see if alloy nuts fit then
if not maybe cut bit of thread off
Post #431353 16th Jun 2015 2:43pm
Culminator
Sorted!
Many thanks for the quick replies Thumbs Up
I didn't think it looked right winding the adjusters so far along the threads but as said, that is how it is!
Anyway, spare securely fastened now, happy days.
Mike
Post #431366 16th Jun 2015 3:50pm
