Home > Td5 > grating / chirping noise at front of engine |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Did you replace the belt too? Guns and Landrovers .... anything else is irrelevant.
11th Jun 2015 1:24pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Hi Dave
belt was replaced last year with LR one...would that make the noise? Andy |
11th Jun 2015 1:31pm |
Possibly, we get it on the Transit variant all the time.
Replacement belt and wipe of all pulleys with degreaser usually solves it ... Try that first before anything dearer ... Guns and Landrovers .... anything else is irrelevant. |
11th Jun 2015 1:43pm |
Crank pulley has a tendency to chirp when switching off engine but I suppose could do it more if it's got to the grinding stage. There's a good Description on discovery2 forum under fixes. Ray
11th Jun 2015 2:14pm |
Went and saw local independent who used a stethoscope and identified the pulley that drives the water pump and I think he said also the power steering. When he spun it it sounded rough and it is booked in for investigation next week. Reluctant to drive it though
11th Jun 2015 5:36pm |
Up date;
it turned out to be the power steering pump. that has been changed and is now a pleasure again to drive without the noise |
19th Jun 2015 8:57pm |
