Home > My Defender > 2002 110 "black" limited edition |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772 |
It'll be worth it in the end should last for years!!! Ray
18th May 2015 9:27pm |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
I collected my parts today, and they have done a top job. And on top of that, they haven't lost any of them!
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge They just need a good sand to get the drips off and to smooth all the visible surfaces and then a swill with a bit of 'T wash'. They will then be ready for the powder coaters on Monday. Oh, and all the threads re tapping to clear them of Galv. 2002 110 td5 |
3rd Jun 2015 7:03pm |
It's all starting to come back together now. I can see why Land Rover don't galvanise these parts though. There has been an awful lot of prep work to get a good paint finish. Also, re tapping the captivated nut seat belt mounts was a little unnerving. Fitting the floor went well although I am not convinced powder coating the aluminium was a good idea. It seems to chip very easily. I guess time will tell and if it looks a mess I can always strip and repaint it. 2002 110 td5
8th Jun 2015 9:20pm |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 2002 110 td5 |
8th Jun 2015 9:23pm |
Sorry about the last picture. It is the right way round on my iPhone but rotates when I upload it 2002 110 td5
8th Jun 2015 9:24pm |
Where did you get the galvanising done? And what have you used on the chassis it looks great keep up the good work!!! Ray
8th Jun 2015 9:26pm |
Dinitrol on the chassis. There are a lot of nooks and crannies under there that are impossible to reach with the floor in. Especially on the offside where the fuel and brake lines harbour crud. Metal treat in Bradford did the galvanising. £113 all together. It cost more to have all the parts sand blasted than it did to have them galvanised. They have a very good finish but will still need a good flatting before powder coating as I am considering gloss rather than satin black. 2002 110 td5
8th Jun 2015 9:33pm |
The other sill is now on and the floor back in. Thankfully, the pop rivet holes line up perfectly behind the rear door. It is nice to look at all the stainless steel fixings that have replaced the rusted items....they have been bugging me ever since I bought it, even though they are hidden under carpet!
10th Jun 2015 8:49pm |
Before and after.....
10th Jun 2015 9:03pm |
Nearly there did you put some plastic washers under the stainless fixings to the floor to stop the dreaded dissimilar metal corrosion? Ray
11th Jun 2015 7:23am |
No. I gave them a good coating of Duralac though. You can just see it in the photos (it is the yellow stuff). If it starts to look as though it is corroding then I may consider this, although I probably won't own it then! There was very little corrosion there in the first place to be honest.
All the brackets underneath have got foam gaskets between them and the body work. 2002 110 td5 |
11th Jun 2015 8:56am |
Excellent work, im trying to go through mine with this level of work Ray
11th Jun 2015 12:33pm |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 |
Looking good, few bits I might have to do on mine. Definitely will follow your example going down the galvanized route.
Yours is certainly a well thought out 110 |
11th Jun 2015 1:33pm |
She is all back together now and passed her mot yesterday.
Click image to enlarge Click image to enlarge Click image to enlarge I had some floor bolts and clips left over so decided to make myself some mud guards to protect the DRLs Click image to enlarge Click image to enlarge 2002 110 td5 |
16th Jun 2015 8:05pm |
